It is currently Sun Nov 22, 2026 6:18 pm
PostPosted: Fri Jun 29, 2007 9:10 am
To quote slantsixdan.
I recently replaced my Carb with a new one from Dan (incredible). I Replaced plugs, rotor, wires and had an oil change. My truck had sat for about two years and I need it to pass Oregon emissions so I am driving it as much as possible to clean it out and lube the system. On my way home from work yesterday, I stopped at a light and with my foot on the brake, it reved uncontrollably high. I let the engine do the work and I made it home safe. I checked the carb the next day and everything looks fine but once the throttle gets past half way, it gets stuck open. Can any one give me some specific direction?
Thanks again
Matt
PostPosted: Fri Jun 29, 2007 9:49 am
Matt,
what type of linkage-- cable or linkage?
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
PostPosted: Fri Jun 29, 2007 10:17 am
Jeff,
Linkage/springs on carb that is where it sticks. Cable from gas peddle is smooth
PostPosted: Fri Jun 29, 2007 12:59 pm
Can you show us a clear, sharp photo of your throttle spring(s) in their installed position? It sounds like one of the springs is going overcentre and holding the throttle open; this can probably be fixed by correcting the spring's position.
PostPosted: Fri Jun 29, 2007 2:47 pm
when I get home and assuming I can figure out (with my vast computer knowledge) how to post a photo. Thanks again and yes the carb is perfect
PostPosted: Fri Jun 29, 2007 9:15 pm
Photos not necessary. Fixed.
Dan, remember me asking about the linkage connectors? One was broken and it wedged between a rod and arm. I still need the connector but it does not stick now. Thanks for opening my eyes.
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
