It is currently Mon Jun 22, 2026 1:19 am
PostPosted: Thu Jul 05, 2007 11:58 am
Any help in decoding this would be greatly appreciated.
M21 M25 M26 M38 V5X END
V1G U 22 F16 G52 L31
KG8 L1G6 KG6 A16 284014
E24 D34 LH41 C4R 135462
PostPosted: Thu Jul 05, 2007 1:58 pm
What's it from?
The Old Goat '83 D150 225-2
AKA Ice Titan
PostPosted: Thu Jul 05, 2007 2:28 pm
It's a '74 Dart sedan.
E24: 225 cubic inch 1bbl 6-cylinder engine
D34: Torqueflite automatic transmission, standard duty
L: Dart
H: High trim/price class
41: 4-door sedan
C: 225 cubic inch, 105 net HP 1bbl 6-cylinder engine
4: 1974 model year
R: Windsor, Ontario build plant
135462: Vehicle serial number
KG8: Paint code
L1G6: Interior trim (Low price class, cloth & vinyl bench, white & green)
KG6: Upper door frame paint
A16: Build date 10/16/73
284014: Vehicle order number
V1G: Black vinyl roof
U: Built to US market specifications
22: 22" radiator width
F16: Unknown fleet/heavy-duty code, possibly alternator-related
G52: Driver's side remote control chrome sideview mirror
L31: Fender-mount turn signal indicators
M21: Roof drip rail moldings
M25: Wide sill moldings
M26: Wheel well moldings
M38: Deck lid finish panel molding
V5X: Black protective bodyside moldings
END: End of codes
PostPosted: Thu Jul 05, 2007 3:01 pm
Car Model: '23 T-bucket
That's not what I got, Dan!
It says..."Jimmy Hoffa's UFO will land on Mount Rushmore during the second blue moon of November".......Oh, wait! I used my secret agent decoder ring..... :oops: ......Sorry. :lol:
Roger
PostPosted: Thu Jul 05, 2007 6:07 pm
KG8: Paint code
'Deep Sherwood Metallic' (There's a Feather Duster across town with this one, it's a nice 'dark Hunter green' look).
That's an alternator code, it's for one that's under 80 amps...but not the little 46 amp wonder...
Sounds like a good car...
 Post subject: Black vinyl roof?
PostPosted: Fri Jul 06, 2007 4:50 pm
It has a green one of similar color to the paint. Non original?[/quote]
 Post subject: Oops, you're right...
PostPosted: Fri Jul 06, 2007 7:19 pm
V1X is a Black full vinyl roof...V1G, is a Green full vinyl roof...
Gotta get Dan a better decoder ring, the inventor of his had too much Molson's...Eh!??!
PostPosted: Sat Jul 07, 2007 4:03 am
So where does one find the tables to decode VIN's like this?
If at first you don't succeed, don't try skydiving.
1984 dodge /6 with Lady, Evony and Breeze
PostPosted: Sat Jul 07, 2007 6:35 am
http://www.stockmopar.com/mopar-fender-tag-decoder.php Image
PostPosted: Sat Jul 07, 2007 9:03 am
Yep, right you are. Something nagged at me as I typed that, but my brain was on the surgery I just got back from having.
Oh, either that or I should get my next decoder ring out of a box of cereal that's not past its "eat by" date.
PostPosted: Sat Jul 07, 2007 9:05 am
That's a good one. There are many lists of fender tag codes out there, and each one seems to contain different omissions and errors, so I like to cross-check codes I'm not completely sure on, to see if I can at least come up with a consensus.
Paint codes aren't provided on any of the fender tag code lists, so (when I remember, thanks DI) I grab the paint code off the fender tag, head over to www.autocolorlibrary.com , look at the paint chip chart for the year and make in question, find the fender tag paint code and retrieve the paint supplier's colour code from the relevant chip.
PostPosted: Sat Jul 07, 2007 9:56 am
Thanks for all of the info
PostPosted: Fri Jul 20, 2007 11:46 am
F16 is for a 34 amp alternator
KG8 - The "K" is for the year that shade was introduced, in this case the 1974 model year. It is a slightly different shade from 1973's JG8 (Dark Green Metallic). KG8 was also used in 1975-76
Bill
Vancouver, BC
