It is currently Tue May 26, 2026 4:44 pm
PostPosted: Fri Jun 29, 2007 7:29 pm
Can you guys help me get a parts list together to convert the front drums to disc's plz?
PostPosted: Fri Jun 29, 2007 9:21 pm
There are lots of ways to do this. Here are a few resources:
http://www.moparaction.com/Tech/archive/disc-main.html
http://www.bigblockdart.com/techpages/d ... sion.shtml
http://www.scarebird.com/
PostPosted: Wed Jul 11, 2007 5:35 pm
Well after reading those i think i may have some of the parts needed on a 86 fith avenue
PostPosted: Mon Jul 16, 2007 2:35 pm
73+ A body donor parts (new or used):
spindles, caliper brackets, calipers, front hoses, rotors, bearings, dust seal, splash shields (nor req., but nice to have) UCAs, lower ball joint, dual master cyl., propotioning valve.
PostPosted: Mon Jul 16, 2007 2:42 pm
Yes, the FJM body spindle can be used on the A body conversion (see BigBlockDart tech pages. Some say no (see mopar action tech pages).
I personally have used the FJM spindles with no problem. From the FJM you can use: spindles, calipers, rotors, splash shields, bearings, seals, hoses, proportionings valve (looks much different than the 73-75 drum/disk valve),
You still need the UCA (I think I have another set kicking around, I'll look)
IF you need pictures, I just did the swap on my 64. The car is for sale, see the ebay link for picts on the brakes.
PostPosted: Fri Jul 20, 2007 7:26 am
wheres the ebay link?? Pictures would help.
PostPosted: Sat Jul 21, 2007 11:56 am
