It is currently Sun May 17, 2026 3:09 am
PostPosted: Wed Sep 05, 2007 1:06 am
hey guys/girls
i am new here and looking for advice on making my slant six powered
1969 ozzie valiant go quicker then a 17.233 @83mph
at presant i am running a 225 60" over with a mild ported head and over size vavles a 25\65 cam with .425" lift a 4bbl edebrock 500 cfm the bottom end is rebalanced .and is driving a 904 with a 2000rpm convertor and 3.23-1 gears and 14" tyres the car`s weight is 1420kg or 3000lb ish
yours the black sheep :shock:
i like it lumpy
PostPosted: Wed Sep 05, 2007 2:24 pm
Welcome to the board! :D
With that MPH you should be well into the low 16's. Is it bogging or spinning off the starting line? :?
PostPosted: Wed Sep 05, 2007 6:47 pm
I agree with Slantzilla
I Have run a best of 16.35 @82 with 3.91's, I was running 17.1@80 with 2.76's with tha same basic setup
That is 3/4 second faster and only gained 2mph
PostPosted: Thu Sep 06, 2007 2:22 am
HEY GUYS/GIRLS
thanks for the quick reply i am running a 3.23-1 lsd
and it is a little hard to get out of the hole but the mid range and top end is pretty good but is does seem to bog a little when you stand on it hard so i have to kinda stage the throttle in to it i feel for the step in the carb from pri to sec on the edelbrock i stand to the kick then once the revs get to bout 2500ish i let it have ti all the shift up 2 at about 5300 ish
does any one know how to crisp up the throttle on a edelbrock...
your sheepishly
the black sheep
i like it lumpy
PostPosted: Thu Sep 06, 2007 6:45 am
You can increase the accel pump shot by moving the tie rod from the pump to the actuator arm to a different hole. May not help much, though. Increasing initial timing while keeping full mechanical advance at 28 deg or so could help.
My general recommendation is to get a nice 3000 stall converter, which will really wake things up, and will not change much about how it drives on the street until you stand on it.
Also, the holley 500 2bbl is a great carb for a medium built 225. Better throttle response than an eddy 500-4.
PostPosted: Thu Sep 06, 2007 9:54 pm
Nice to see another Aussie here.
Firstly, I can't believe Slantzilla didn't recommend you use some "bottled horsepower" :D
I agree, higher stall, and maybe sticky tires(if you're having traction problems). Are you using the stock ignition system? As mentioned before, 83mph is definitely good for a quicker ET. I've run a 16.3 @ 84mph, and I've been told that speed is good for a quicker ET......??????
Are you a member of Mopar Market black sheep??
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
PostPosted: Fri Sep 07, 2007 1:50 pm
Got to get it to run right first. Adding the hose now would just mask the real problem. :lol: :lol: :lol:
PostPosted: Fri Sep 07, 2007 5:28 pm
hey guys/girls
yes i am running eletric ingtion its a crane cams optical kit the goes in to the dizzy i think its called a xr 700 the dizzy is stil nor recurvred as yet and my total timming is about 30-32`D the coil is a matched crane coils unit ps90 ( very big spark!!!!! does hurt ..)
and i checked the convertor in my engine build/trans book i kept the stall was lifted 500-700 over stock
i watch some vids of my at the drags and there seem to be no major wheel spin issuses happening
today i will try adding more acc pump shot to clean up the throttle response it i am also going to clean the k&n filter to it looks a little dirty
oh and SV162 i am not a member of mopar market but i do know the web site .
al thought in a total picture i think i need a good lsd +lower gears and a mopar ele dizzy
you getting shawn today
the black sheep
i like it lumpy
PostPosted: Fri Sep 07, 2007 10:51 pm
you should slap those vids up somewhere like youtube or something i'd get much joy at watching you car dominate some dragstrip. I got some videos but on a friends computer one of these days i'll figure out how to get them on somewhere :) I'm rebuilding my baby as we speak.
Good luck man have fun be safe oh and i wouldn't mind a lesson on distributor recurving (wink wink someone)
Kevin
PostPosted: Sun Sep 09, 2007 12:23 am
HEY ALL
it`s the black sheep again here a vid that i am in i am the black vailant 4 door right and the end of this video . draging my brothers wife in a blue and orange ute we both run 6cyl engines mine is a slant of course and the ute runns a 245CI hemi motor 4bbl .. this vid is for mopar sunday 2006
http://www.youtube.com/watch?v=uA7NesWufaE
enjoy the ozzie mopars
yours now feeding the black sheep
i like it lumpy
PostPosted: Sun Sep 09, 2007 10:39 am
Sweet car man it looks tough black i'm trying to get some videos up soon or just make new ones when i get the car goin again.
Kevin
PostPosted: Mon Sep 10, 2007 2:17 am
hey all
is there any way to post pictures here
yours now drinking a bourbon
black sheep
i like it lumpy
PostPosted: Thu Sep 13, 2007 2:25 pm
Car Model: 69 Valiant 225, 70 with a 265, 70 with a 318
Gday Black sheep, good to see more Australians here.
Say g'day to Mike and Helen for me.
(they know me as Fingers from Hemi6 forum)
Richard (aka Fingers)
