It is currently Mon Jun 15, 2026 10:28 pm
 Post subject: K Frame bolt torque
PostPosted: Sun Sep 09, 2007 9:58 pm
Anyone know the answer to this one. Can't find the spec listed in the fsm.
I dropped the k frame and rebuilt everything on my 73 Duster. Putting it all back together but I cant find the torque spec for the four bolts that hold the k frame to the frame rails. They are a pretty big bolt so Iam thinking between 75 and 100 ft lbs at least but if someone knows the exact spec it would be appreciated.
Thanks
Brent
73 NorthernDuster
Arizona Duster in Canada
PostPosted: Mon Sep 10, 2007 2:33 am
TIGHT.
never had a problem with them coming loose. and that is with a lot of enthusiastic use way and above a normal road car.
there probably is a specified torque somewhere,but the size of the bolts is "agricultural" to say the least,so old farming technique -" make sure them bolts is tight as you can get 'em son."
always worked for me.
regards,Rod :D
PostPosted: Tue Sep 11, 2007 9:07 pm
I use German torque values....goodentite.
There are 3 things that will live forever, cockroaches, Keith Richards, and Slant Six Dusters !!!
http://s4.photobucket.com/albums/y128/slantasaurus/
take a look around
PostPosted: Wed Sep 12, 2007 4:37 am
Check em again after you have driven the car a bit and things have settled.
This is good advice for most things in the supension.
Sam
 Post subject: Thanks
PostPosted: Wed Sep 12, 2007 9:00 pm
Thanks for all the input
I guess I'll pull on them till my back gives out. Then it will be time for a beer.
Cheers
PostPosted: Thu Sep 13, 2007 11:52 pm
150 foot-pounds according to the Field Service Manual for my 1963 Dodge Dart GT.
An A body is an A body in this regard, I suspect, whether a 63 or a 73.
Hope this helps.
--Walt Jackson
