It is currently Tue Jun 09, 2026 4:43 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Tue Oct 02, 2007 4:15 pm
That is exactly what I want to do. But without the roller rockers.
PostPosted: Tue Oct 02, 2007 9:30 pm
If I decide to make the shims, they will look like the bottom half of those in the pic. You would still use the washer on top of the rocker shaft. Basicly make that part, cut it through the centerline and you would have two of the shims.
Excuse me, does this smell like chloroform to you?
PostPosted: Tue Oct 02, 2007 11:10 pm
Will, how did that trucks body get so messed up?
PostPosted: Tue Oct 02, 2007 11:16 pm
Will , who makes those rockers you are using?
Charlie, there you go, just what you ordered. Maybe you can talk him into making some for you. Although the height that will be needed will be effected by the valve height used in each head.
Jess
PostPosted: Wed Oct 03, 2007 3:41 am
Jess
I have to figure the dimension, from the base to the centerline. Before I can do that, I need to determine the hight of the cut off stand.
PostPosted: Wed Oct 03, 2007 9:41 am
The truck got messed up when a dog ran in the road and caused a 6 car pile up.
the rockers were from Mark from the green team and are no longer avaible. Cox Bros can get you a nice set from rocker arm specialties
eather 1.5 or 1.6.
