It is currently Thu Dec 25, 2025 9:06 pm
 Post subject: strut rods
PostPosted: Tue Oct 02, 2007 7:44 pm
Hey guys,
Strut rods the same for all A-bodies? I have my eye on a set for my '65 Valiant, but they're from a '73-up car. I already have LCAs from a later car. Also, any harm in buying a used set?
Thanks,
PostPosted: Tue Oct 02, 2007 9:10 pm
no they are not all the same--- I believe-- the 62-72 cars are the same --fine thread on both ends-- the 73 up cars have a coarse thread on the "K" portion. Also the newer style is slightly shorter than the old. Lawrence
PostPosted: Wed Oct 03, 2007 11:21 am
Glad I asked!
Thanks for the info, much appreciated.
PostPosted: Mon Oct 08, 2007 8:46 pm
The newer style of strut rod works very well with a '65. I am running a set from a '75 Dart along with the LCA's.
PostPosted: Tue Oct 09, 2007 12:29 pm
Not to totally discount what VDart said, but I've recently learned from two different parts suppliers that they are indeed the same from '63-'76. (At least as far as what they sell.)
Seems the only difference is that some newer repro ones are just a larger diameter.
Thanks.
 Post subject: strut length
PostPosted: Tue Oct 09, 2007 4:41 pm
I did not measure but had them side by side & there is a difference in the length of the s/rods. This was also shoulder to shoulder area --not just overall length.
One of the suspension geometry guru's can tell you the effect of longer/shorter strut rods on your alignment specs-- I do not know.
PostPosted: Tue Oct 09, 2007 7:35 pm
A shorter effective strut rod length gives more positive caster.
PostPosted: Wed Oct 10, 2007 4:10 am
True, but caution is needed. Too short and it will pull the LCA into a bind and hurt handling.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
