It is currently Fri Oct 09, 2026 11:23 am
 Post subject: aluminum and pipe plugs
PostPosted: Sat Oct 13, 2007 3:36 pm
The Offy has a threaded fitting for a a vacuum fitting.
I'm not using it, so I'm putting a pipe plug in it.
What is the best material to use in the aluminum intake?
I picked up a brass one, though the fitting was steel. Is there enough heat to be worried about expansion rates? Should I use Steel instead?
Probably doesn't matter, but just in case! :)
PostPosted: Sat Oct 13, 2007 4:04 pm
Really doesn't matter. Use what you have. Brass is good.
PostPosted: Sat Oct 13, 2007 4:15 pm
Thanks Dan!
PostPosted: Sun Oct 14, 2007 6:16 am
Brass plugs seem to come out of old aluminum castings the easiest.
If you use a steel or cast iron plug, be sure to use a little anti-seize compound on it.
Users browsing this forum: Google [Bot] and 25 guests
