It is currently Sat Oct 24, 2026 4:36 am
 Post subject: 170 to 225 long block
PostPosted: Wed Jul 24, 2002 12:57 pm
I am going to make this switch in my 68 Dart no AC.
Will the accessories transfer over or do I have to buy new ones ?
Thank you,
Ed M.
edmorris@bee.net
PostPosted: Wed Jul 24, 2002 3:11 pm
: I am going to make this switch in my 68 Dart
: no AC.
: Will the accessories transfer over or do I have
: to buy new ones ?
: Thank you,
: Ed M.
i swapped a 170 into my '63 valiant and (if i remember right) all the accessories swapped over fine. you may need a new alternator belt as the alt will sit an inch higher with the 225. also the exhaust pipe may need to be extended to compensate for the higher manifold for the 225. my old exhaust had to be bolted up with the motor jacked up (soon to be fixed this week.)
-james
ludite13@cs.com
PostPosted: Thu Jul 25, 2002 11:38 am
: i swapped a 170 into my '63 valiant and (if i
: remember right) all the accessories swapped
: over fine. you may need a new alternator
: belt as the alt will sit an inch higher with
: the 225. also the exhaust pipe may need to
: be extended to compensate for the higher
: manifold for the 225. my old exhaust had to
: be bolted up with the motor jacked up (soon
: to be fixed this week.)
: -james
Thanks for the info James. Can you also tell me if the valve cover & oil pan will fit ?
edmorris@bee.net
PostPosted: Thu Jul 25, 2002 4:13 pm
: Thanks for the info James. Can you also tell me
: if the valve cover & oil pan will fit ?
ed-
they should fit fine. just swap the ones off you old motor. most of the valve covers are pretty much the same, the only differences being in the pcv/breather types. the oil pan is critical as there are different shapes to clear various subframes. just use the one that came in your car. you'll be ok.
-james
ludite13@cs.com
PostPosted: Fri Jul 26, 2002 8:07 am
: ed-
: they should fit fine. just swap the ones off
: you old motor. most of the valve covers are
: pretty much the same, the only differences
: being in the pcv/breather types. the oil pan
: is critical as there are different shapes to
: clear various subframes. just use the one
: that came in your car. you'll be ok.
: -james
Also use the oil pickup that go with the pan.
flturbo6@aol.com
PostPosted: Fri Jul 26, 2002 10:01 am
: ed-
: -james
Thanks for the info. You are a wealth of information.
Tanks again,
Ed M.
edmorris@bee.net
PostPosted: Sat Jul 27, 2002 3:20 pm
: Also use the oil pickup that go with the pan.
whoa, how could i have forgotten that? thanks charlie! my bad!
Users browsing this forum: Google [Bot] and 17 guests
