It is currently Sun Apr 26, 2026 6:30 am
 Post subject: running hot
PostPosted: Tue Oct 23, 2007 10:38 am
I have an unknown replacement /6. It was low mileage but appeared to have been poorly maintained. At startup it ran hot. Radiator has been recently serviced, new 180 deg. thermostat. I plan to get a new bottom radiator hose which looks suspicious. But the real problem seems to be block passages. I removed the engine drain plug, and nothing comes out even when running. Any remedy for this.
PostPosted: Tue Oct 23, 2007 11:49 am
Push a screw driver in the hole and loosen up the rust so it will drain. You can also use a coat hanger once you are able to break through the crud. Try to flush it out with some radiator flush. Then add anti-freeze to keep it cool and from rusting up again.
 Post subject: Sounds cheap and easy.
PostPosted: Tue Oct 23, 2007 12:09 pm
Thanks Aggressive Ted, that sounds like a good place to start. Before I start pulling cylider heads. Before I really get aggressive.
PostPosted: Tue Oct 23, 2007 12:10 pm
With an engine as crudded-up as yours seems to be, you will need something a good deal stronger than a "radiator flush" chemical. See this thread and this one .
 Post subject: hot running
PostPosted: Tue Oct 23, 2007 4:16 pm
Just a FYI. We had a slanter that ran hot and beat our heads trying to figure it out. Turned out being a waterpump impeller that was loose and spinning on the shaft. No play in the bearing no leaks but a bad waterpump.
 Post subject: Chillin out
PostPosted: Wed Oct 24, 2007 4:30 pm
Aggressive Ted's screwdriver/coathanger ream job seems to have done the trick. :!: I was ready to order the chemical peel recommended by Slantsix Dan, (his word is law around here), but might hold back on the $20.00 investment for now, until cash flow picks up. I flushed everything out with some can of flushing stuff that I had on hand, and flow is way improved. On to transmission and rearend for next big problem. Thanks for all help.
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
 Post subject: Re: Chillin out
PostPosted: Wed Oct 24, 2007 4:35 pm
Naw, it iѕn't! I know, 'cauѕe I ѕaid ѕo, and that makeѕ it law! :lol:
Be careful, you're now looking at a bunch of looѕened-up crud floating around through the cooling ѕystem. It will tend to clog up your radiator, ѕo keep a ѕharp eye on thingѕ. Remove the rad cap from time to time and look at the topѕ of the tubeѕ to check for chipѕ and chunkѕ.
PostPosted: Wed Oct 24, 2007 8:31 pm
Dan,
You need to repost the link to those fancy floatsom and jetsom clear filters with the removable screens to filter the crud out.
PostPosted: Wed Oct 24, 2007 9:01 pm
Cheap, easy upper radiator hose trap.
http://www.slantsix.org/forum/viewtopic.php?t=25282
Gano Inline Radiator Filters
https://www.mustangsplus.com/xcart/home.php?cat=2163
PostPosted: Wed Oct 24, 2007 9:04 pm
Right here.
 Post subject: again, cheap and easy.
PostPosted: Thu Oct 25, 2007 9:33 am
It looks like the upper hose screen might be within my budget.
 Post subject: Overheating?
PostPosted: Sat Oct 27, 2007 10:43 pm
Once you get the water jacket unclogged and flushed out here is another thing to try.
If you want that engine to really run cold, use the MOPAR 5 blade flex fan and clutch fan part number DCC-4120758 in the Summit catalog. I bought one because my old clutch fan lost it's seal and all the oil drained out which caused it to lock up full time. The local NAPA and other Parts stores didn't have the right depth clutch fan units. They all were too long and would hit the radiator. As it is mine is about 1/2" or so away. It runs much cooler than the stock 4 blade and the mileage went up about 1.5 to 2 miles per gallon. You definitely don't need a fan shroud.
This unit will definitely keep you car running cold. I run a 195 degree stat just to get some heat. In hotter climates it should work very well. :)
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 3 guests
