It is currently Thu Nov 26, 2026 11:48 am
PostPosted: Wed Oct 24, 2007 4:40 pm
I replaced the stock three speed manual in my 67 a-body with an untried four speed, "It oughta just bolt in". Trans came with oldish Hurst shifter. Problem is sometimes I have second gear, upshift or downshift, and sometimes won't go into second. Everything else works ok. Does anyone with experience in this area have a feeling of whether this transmission is junk? It seems strange that it sometimes goes into gear and sometimes not. :?
 Post subject: shifter
PostPosted: Thu Oct 25, 2007 4:03 pm
Check your shifter rods for stripped threads. My friends son was having the same problem with his Cuda and would not hold adjustment. Just a thought..........
 Post subject: On the right track
PostPosted: Fri Oct 26, 2007 2:15 pm
I think you're right to think shifter, Romeo Furio. I took the car out today, and found I can always get it into second if I shift into fourth and then over into second. Shifter is old, but threads on adjusters are not the problem, since I had to torch them to get the cams to adjust out to the right position, so that everything is in neutral when a pin is in all the line-up holes.
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Sun Oct 28, 2007 6:08 am
sounds like synchronizers are bad...
65 Coronet, 4 bbl, .060 over, mild cam.
66 Valiant, Black, 3spd, Hyperpak, headers.
works in progress...
 Post subject: and that ain't good
PostPosted: Sun Oct 28, 2007 8:46 am
That's what I'm afraid of.
 Post subject: Back out
PostPosted: Sun Oct 28, 2007 4:38 pm
OK transmission has been pulled. Now should I monkey around with this myself or is this a job best left to a "qualified repair shop" as the repair manual suggests. How much should I expect to pay for a rebuild? Or is a junkyard replacement the way to go? Opinions welcome.
