It is currently Tue May 19, 2026 12:49 pm
 Post subject: Question about a Neon
PostPosted: Wed Oct 24, 2007 10:31 pm
Hey everyone i know this is a slant forum but i couldn't find an answer anywhere else and i knew someone on here could help.
Anyways i was gonna do a tune-up on my girlfriend's '03 Neon (or SX 2.0, whatever you want to call it), and i figured on changing the plugs, air filter, wires, oil, oil filter, maybe a coolant and transmission flush, and probably the PCV valve depending on what condition it was in. Now i know on my '62 i would change the fuel filter too if i was gonna do a tune up, but i heard that the fuel filters are in the tank on these cars, so do they need to be changed/do i need to drop the tank or use special tools? If so i'm probably better off taking it to a dealer.
Thanks a ton!
Allen
1962 Valiant V-200
170 C.I. Super Six, HEI, Dutra Duals
PostPosted: Thu Oct 25, 2007 4:11 am
Well as with any car, some type of service manual would likely be a wise investment, and in that you will find the location for the fuel filter.
They are usually underneath near the tank or low on the firewall, additionally what you will find is that there is a pre-pump filter or "strainer" in the tank. This strainer only requires service if the pump is replaced.
Good luck on your tunin'
.020 off the block .100 from head
Comp 264
904 Tranny
New Ebre-ting
http://s78.photobucket.com/albums/j103/edrod01/
PostPosted: Thu Oct 25, 2007 5:54 am
I am not sure on the 03 neon, but many cars/trucks, are going to the complete fuel pump/pressure regulator/filter module in the tank.
PostPosted: Thu Oct 25, 2007 8:41 am
Car Model: 63 Dart 81 D150
I think the neon is still external near the tank. Ask NAPA to see the filter, by looking as it you should be able to tell if it looks like its external. On an 03 you may need a special disconnect tool. You should be able to get it from "loan a tool" at the parts store. They are not expensive to buy either.
My Mitchell labor guide calls for 0.5 hours to change the filter/regulator assembly on all 1997-2005 neons. They call for 1.1 hours to R&R the tank, so it has got to be external.
good luck
TopHat
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
