It is currently Wed Nov 25, 2026 3:45 pm
 Post subject: Will not start in Park
PostPosted: Mon Nov 19, 2007 8:58 am
I had to drop the steering column in order to disconnect the speedo cable until I can get the speedometer rebuilt. After i put back together the car will sometimes not start in park. (about 50%) It does start in neutral but i like things to work correctly. ANy ideas on what i need to adjust/check in order to fix?
PostPosted: Mon Nov 19, 2007 9:25 am
Gearshift linkage. Check bushings and replace as necessary, then adjust per service manual. The Neutral Safety Switch isn't being properly engaged when in Park.
PostPosted: Mon Nov 19, 2007 1:32 pm
my car used to do that ater i messed wit colum. to get it to start i would hafta push up pretty hard on the colum shifter, this would rotate the colum a bit to enageg the neutral safty. did that until i loosend colum and retightend it.
