It is currently Mon May 11, 2026 3:19 pm
 Post subject: Hood Hinge lube
PostPosted: Thu Nov 29, 2007 11:12 am
Whats the best way to lube the hood hinges? Im having trouble getting the hood up and down without bending it.
Thanks
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Nov 29, 2007 11:56 am
You ought to be able to break loose the frozen rollers at the ends of the hood torsion bars by using a good penetrating oil such as Kroil or P'Blaster (forget WD40 or Liquid Wrench). Then apply a couple of drops of regular engine oil to the rollers where the bars go through 'em, and to the actual swing hinges.
PostPosted: Thu Nov 29, 2007 1:12 pm
Ill use PB.
Thanks Dan as usual you are a wealth of info.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Nov 29, 2007 7:00 pm
After you get it broken loose, I use grease to keep it protected. I pack it with grease and wipe the excess off to make it look cleaner and protect it from sticking again later.
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
 Post subject: grease
PostPosted: Fri Nov 30, 2007 8:03 am
Try BOAT wheel bearing grease that is water proof.
PostPosted: Fri Nov 30, 2007 8:06 am
Thanks Dave and Romeo
Those are great tips.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
