It is currently Tue May 19, 2026 1:13 am
 Post subject: ratios?
PostPosted: Thu Jan 03, 2008 12:36 pm
does anyone know off hand the 1st and 2nd ratios for both the 904 and the low gearset 904?
PostPosted: Thu Jan 03, 2008 1:25 pm
904 (standard ratio) 2.45, 1.45 & 1.00 to 1
998 / 999 (wide ratio) 2.74, 1.54 & 1.00 to 1
PostPosted: Thu Jan 03, 2008 9:54 pm
Is the 2nd to third shift in the 998 set extreamly noticeable, i.e. big difference from the 904?
Even in moderation i am excessive!
PostPosted: Fri Jan 04, 2008 5:39 am
That is the problem with using a low gear set with a Slant. What you gain in low you give back on the 2-3 shift. :(
PostPosted: Fri Jan 04, 2008 11:45 am
I've got a solution for that coming in the mail. :twisted:
