It is currently Wed Jun 24, 2026 4:49 pm
 Post subject: What Cam Is This
PostPosted: Sun Jan 13, 2008 4:30 pm
When I picked up my new ride last week, the owner told me the cam in it was either a "453" or "435" by Chrysler. I wasn't too concerned over specs since he went on to say they were in the pile of paperwork he provided at the time of sale. Yep, you guessed it...wasn't there. There is evidence he bought the camshaft for the 225 from a local Dodge dealership. Got any ideas?
PostPosted: Sun Jan 13, 2008 4:33 pm
I just found a part # hidden away: P4286571. Hope that helps.
 Post subject: Re: What Cam
PostPosted: Sun Jan 13, 2008 4:58 pm
That part # is for an oil pump high pressure relief spring for G, RG, B, RB and Hemi.
Slant Cecil
PostPosted: Sun Jan 13, 2008 5:13 pm
I guess he wasn't thorough as I thought...put the wrong part # on the wrong line in the spreadsheet. Thanks for the correction. He wrote P4120243 on the next line for the Oil Pump Hemi Spring on the same date. Could that be the missing #?
PostPosted: Sun Jan 13, 2008 5:25 pm
MP244 methinks
PostPosted: Sun Jan 13, 2008 5:28 pm
mech cam, 244/244 adv duration, .436" lift, 28* overlap, .010/.020 lash, 108* cam c-line, 106* install c-line
This is a good cam for a daily driver if you only want a bit more performance, it's not much bigger than the OEM '71-'80 cam
Slant Cecil
PostPosted: Sun Jan 13, 2008 7:18 pm
Cecil Figured it out, But This handy Chart compares what you have to what else it out there..
http://www.hal-pc.org/~bwhitejr/Slant_Six_Cams.pdf
PostPosted: Mon Jan 14, 2008 5:03 am
Thanks for the help from both of you! I know the cam isn't much "bigger" than stock, but I can really feel the difference this, and other mods (dutras, offy intake, 4 bbl) have made in my 63 Valiant. Its much different driving this car as compared to my bone stock 69 Valiant.
PostPosted: Mon Jan 14, 2008 9:08 am
I like the MP P4120243 (244°) cam. Got one in my '62. True, this cam is a small step up from the '71-'80 stock cam, but your '69 hasn't got that cam, it's got the '65-'69 cam, which is a little smaller and shorter (but a little larger and longer than the '60-'64 cam). And, the cam in the '63 might've been carefully centrelined (degreed-in) upon installation, while the '69 cam was just thrown in at the factory. So I'm not surprised you'd detect a difference, even if both engines had the same carburetion.
PostPosted: Mon Jan 14, 2008 12:01 pm
Like this website says, "This isn't your grandma's Slant Six".
Mine really perked up as well after the rebuild. My lift is the same (.435) but the duration is little longer.
I sure enjoy driving mine now! :D
 Post subject: What cam is this?
PostPosted: Mon Jan 14, 2008 5:20 pm
I will post an updated version of this spreadsheet if anyone has more things to add. I already have two CompCams revisions to put in.
I can post it as a *.pdf or Excel or both. :)
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Mon Jan 14, 2008 6:54 pm
Bwhitejr
I have the original as a pdf. When you get the changes made shoot it to me @silverhairbeaver@hotmail.com remove the first @.
Thanks
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Jan 15, 2008 5:57 pm
Thanks bWhitejr!!
PostPosted: Thu Jan 17, 2008 2:33 pm
I updated the CompCams entries and reposted the spreadsheet.
bwhitejr
0.090 Shaved Head
PostPosted: Thu Jan 17, 2008 3:19 pm
Does this include Doc's last two split lift cams he designed for Erson?
If so, what line number are they on.
Thanks,
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
