It is currently Sat Oct 10, 2026 6:05 am
PostPosted: Sun Jan 27, 2008 3:41 pm
Hello all, I have a 68 225 w/ the drool tube head. will a later model peanut plug head go onto it?Will I have to run the later rocker assembly? I guess I just need to know the interchange......I am trying to get away from the drool tube for my race motor.
Any suggestions are greatly appreciated!!
Andrew
Wife's: 64 Valiant
PostPosted: Sun Jan 27, 2008 4:36 pm
Andrew,
I am using a 1978 peanut plug head, instead of the 1974 drool tube head on mine with no problem. Push rods and all fit just fine. I kept the 78 rocker assembly that cam with the head. I believe the assembly is interchangeable.
I never like the drool tubes either. The new head does keep the engine allot cleaner. I have about 24,000 on it since the rebuild. Just be sure to seal the lower edge of the block with a little extra sealant and you will be fine. See Docs post for reference. See the "Oil leaking from block" post. It is on page two at the moment.
 Post subject: Yep...
PostPosted: Sun Jan 27, 2008 7:46 pm
You can plug any slant head on your block, and the assemblies are interchangeable (except the 1981-1987 rocker arms meant for the no adjust hydro cam)...
One thing to note for the record I have a 1979 head, and the rear bolt on the rocker shaft is smaller (bore in the rocker shaft is also drilled slightly smaller) than the pre-78 heads (might be the 'tween change before the hydro cam heads came out...)
PostPosted: Mon Jan 28, 2008 4:44 pm
Thanks- So I can run the later head w/ paenut plugs, and run the earlier adjustable rockers? I have a new Comp cam....and springs....and will beed to get the valve lash right.
Andrew
Wife's: 64 Valiant
PostPosted: Mon Jan 28, 2008 5:16 pm
Yes, the peanut plug heads I have seen through 1979 have all been adjustable.
PostPosted: Mon Jan 28, 2008 6:15 pm
Now to start keeping an eye out for one.Thanks !!
Andrew
Wife's: 64 Valiant
PostPosted: Mon Jan 28, 2008 10:50 pm
I have a few of them... drop me a PM.
PostPosted: Tue Jan 29, 2008 7:09 am
Hello Kidd!
You will find a thread in the forum in which various guys report various numbers of manifold studs holes going into the water jacket. Although a curiosity that they vary, it suggests that whatever head you use you might want to be sure to seal ALL the studs from water leaks unless you know for certain a hole doesn't need it.
And not to steal from Doc, but I have a peanut head I would give away for shipping even though I had it hot tanked and magnafluxed as perfect. I am doing a great parts get gone since I basically finished my project.
rock
'64d100
Users browsing this forum: Amazon [Bot], Google [Bot] and 33 guests
