It is currently Tue Oct 13, 2026 10:42 pm
PostPosted: Tue Jan 29, 2008 11:40 am
i have a 2dr 69 plymouth satellite with a 225 slant6 with a 3spd manual tranny...
i also have a t3 turbo charger and 500cfm holley 2barrel set up which i plan on putn on the satellite to fill in the extra space under the hood of my b-body...
i was wondering how much boost do you think i could turn with stock internals?
PostPosted: Tue Jan 29, 2008 12:21 pm
The SL6 has been known to handle in excess of 400 HP....
That 903 , non-syncrow 3-speed has been known for "blowing-up" behind stock engines.
You need to change-out the 3-speed before installing a turbo.
PostPosted: Tue Jan 29, 2008 2:06 pm
i heard that a small block 4spd tranny will bolt up to a slant 6? is this true?
what tranny do you recomend? i would like to keep it manual.
yea my roadrunner is a six pack! 225 six pack!
ill throw twins on the slant6 just to watch there jaw drop when i lift off the six pack hood.
PostPosted: Tue Jan 29, 2008 2:15 pm
If you don't want an overdrive look for an 833, 4 speed '74/5 ish or older. the 75/6ish and newer look the same on the outside but 3rd is like yours now, and 4th gear is O.D. There are several recent threads on this very subject; one in particular that I am thinking of pertains to such a swap on an A body but aside from a different driveshaft tunnel "hump" for your B body, and the fact that the B's generally took the "long tail" version of this trans, the how to is the same.
PostPosted: Tue Jan 29, 2008 3:02 pm
Also review the 4-speed article.
http://www.slantsix.org/articles/4-spee ... speed1.htm
You will find that your car is a lot more fun to drive when you have more gears to use and you can shift into 1st gear with-out coming to a stop.
PostPosted: Tue Jan 29, 2008 5:06 pm
hey thanks alot!
also...
what year and body style were these trannys most common in so i will know where to begin to look?
when i swap the 3spd for the a833 will i be able to use the same drive shaft?
PostPosted: Tue Jan 29, 2008 6:27 pm
This should probably be in the trans forum, but how much will the A-833 4spd O/D in my truck handle?
Is there a 5spd that will bolt up?
'81 D150 2WD shortbed 4spd OD.
Users browsing this forum: No registered users and 17 guests
