It is currently Mon Jun 01, 2026 10:27 pm
 Post subject: Tire PSI for the track
PostPosted: Fri Feb 08, 2008 2:35 pm
I am running BFG 235-60-15 on 8" wheels. I have been running 35psi and I am expecting to start having traction problems once I change the rear gear. What would be a good starting point for reducing the pressure to help with traction?
PostPosted: Fri Feb 08, 2008 2:40 pm
When running my Dacuda with 225/50-15s reduce them to 22 psi to start and let additional air out if traction is still a problem. I have run them as low as 18 psi on really slick tracks.
PostPosted: Sun Feb 10, 2008 7:43 pm
add extra for the front for less rolling resistance.
