It is currently Tue Jun 16, 2026 2:43 pm
Post new topic  Reply to topic  [ 29 posts ]  Go to page 1 2 Next
 Post subject: What engine do I have??
PostPosted: Sun Feb 10, 2008 10:30 am
I picked up a slant 6 (lucky me) from the junkyard yesterday and they said it came out of a 1990 s10. I didn't know the s10 came with a slant 6, and the only numbers I've been able to find on the block are 330-3 and 2820 on one side, and just 2820 on the other. I can post pictures if that will help. It was colored blue when I got it, and covered with a $#!+ load of grease or something. I'd love to rebuild this thing and make it run like new, only I don't know which rebuild kit to buy because I don't even know what kind of engine it is. lol. So can someone help me figure this out? =D
PostPosted: Sun Feb 10, 2008 10:34 am
Slant 6s didn't come in Chevys. Didn't come in Dodge Dakotas either. They did come in plenty of Chrysler Corp passenger cars and truck though.
Read this to help you ID what you have.
http://www.slantsix.org/articles/dutra- ... blocks.htm
Looking over that article it looks like it doesn't cover the later blocks that used cast cranks. If you don't have the large casting numbers as shown in the block article you could very well have a mid '76 or later cast crank 225.
PostPosted: Sun Feb 10, 2008 10:52 am
Are you sure they didn't say "Aspen"? Although they didn't make those after 1980 or so.
'81 D150 2WD shortbed 4spd OD.
PostPosted: Sun Feb 10, 2008 10:57 am
So is this a good engine for putting in a truck? It looks pretty badass, it's so huge lol.
PostPosted: Sun Feb 10, 2008 11:12 am
Post some pictures and we'll see if we can help ID your engine. Post them on Photobucket or the like and use the Img tag.
PostPosted: Sun Feb 10, 2008 1:15 pm
Is there any particular part I should try to get a picture of? Like I've been trying to get the exhaust manifold off (it looks like the carb sits right on the exhaust manifold)
PostPosted: Sun Feb 10, 2008 1:42 pm
Here is the engine, if you want a different angle I can do that too.
Here is some random number I found on the block (2820) there is also 330-3 printed on the left of it. (Not in picture)
This is what was on the little sticker on the top of the motor.
PostPosted: Sun Feb 10, 2008 2:59 pm
Look for a machined pad with numbers stamped, not cast. It's about 1/4 wide just below the frontmost spark plug at the mating surface between the head and block. Post those number if they are there and someone will be able to decode them for you.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Feb 10, 2008 4:13 pm
Here is a bunch of numbers on a thingy under the plugs and filter. (2462986 with the words UP over it)
Here is under the 1st plug nearest the flywheel.
PostPosted: Sun Feb 10, 2008 4:17 pm
Look at the other end of the block, the water pump end immediately under the #1 spark plug. It is a horizontal milled suface. You may need to clean the gunk off of it to see anything.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Feb 10, 2008 4:56 pm
Underneath the other end's plug was the coil, which I removed. Here is what was there after I removed the coil and scraped the gunk off.
Did I not look in the right spot? Sorry if I misread your post.
PostPosted: Sun Feb 10, 2008 5:05 pm
Site Admin
David was refering to the machined surface the head bolts to. It's behind the bracket on the front of the engine under spark plug #1. You would look down onto it where the spark plug is. By the looks of things, you won't see the stamped number until you clean things up.
This engine is Huge? :shock: I must be getting old! :lol:
CJ
PostPosted: Sun Feb 10, 2008 5:37 pm
I FOUND IT! I took the mount off and cleaned the top of the cover. WOW. The numbers read 225 T4 22E then a little symbol thingy. So...what does it mean? Thank you for your help!
PostPosted: Sun Feb 10, 2008 6:06 pm
There are a couple of guys on here who know how to decode that. I'll have to wait for one of them to answer; but that's the info that's needed.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Feb 10, 2008 6:30 pm
It's a 225 that's for sure. The rest will tell the year and stuff.
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
