It is currently Mon Jun 08, 2026 10:15 pm
PostPosted: Wed Feb 20, 2008 11:42 am
bought my ride 4 weeks a go. now it dies @ idle...new plugs.new rotor..cap...plug wires..still dies..well I don't have a shop manuel...it came with a haynes but all the book says is to look for the timming spects under the hood on the emissions sticker. sticker there but just diagrams no time/ing info ..any one know the time/ing ? thank you
Image[/img]
slant six's RULE!
http://www.usajon.com
PostPosted: Wed Feb 20, 2008 12:45 pm
well my duster with the /6 died at idle too. turned out to be a dry rotted fuel line, then just needed the mixure on the carb redone after that. though my duster is a 76. have you checked out the fuel lines though?
1976 Plymouth Feather Duster
2002 Dodge Dakota 4.7l v8
PostPosted: Wed Feb 20, 2008 2:18 pm
no. did it leak?
I think it may be a dead idle control valve...it looks eletric and it does not move cold or warmed up...
any idea of the time/ing set...I put a light on it and the pully mark (which i marked with a soapstone) wasnt even on the degree plate it was futher down to the left looking down from the front of the motor, and I move the distributor to get it in the middle of the degree palte...it jumped around quite a bit...why would it do that? motor has 156K super clead when i replaced the valve cover gasket. 1 owner truck when i bought tit.
slant six's RULE!
PostPosted: Wed Feb 20, 2008 2:57 pm
youtube video...there's a lot of under the hood noise..air pump has pin holes for about 1 inch..motor itself is quiet..motor does jump around @ idle...probally to low too.
http://www.youtube.com/watch?v=4VVCGqp1npE
slant six's RULE!
PostPosted: Wed Feb 20, 2008 3:02 pm
no i didnt notice any leaks at all from it. i think it was lack of pressure... i dont know about the timing, i havent had to do that is so long. since the duster any way, i havent driven it in 5-6years. plus im having to learn/relearn the car stuff.
PostPosted: Wed Feb 20, 2008 3:19 pm
Welcome on the board. Correct ignition timing depends on the part number of your truck's spark control computer, as follows:
4289601: 16 deg
4289603: 12 deg
4289613: 12 deg
4289615: 16 deg
4289617: 12 deg
4289621: 12 deg
4289637: 8 deg
The spark control computer itself is a prime suspect with problems like this. It should be eliminated if your local regulations permit it. Start by reading this thread.
PostPosted: Wed Feb 20, 2008 6:14 pm
was this called the majic box back in the day ? has a plug with two holes in it ?
is this the unit ? it does not have those numbers you've listed ?
slant six's RULE!
PostPosted: Wed Feb 20, 2008 8:19 pm
That is your voltage regulator......not much magic from it......
PostPosted: Wed Feb 20, 2008 8:42 pm
Ha!
well what/where is the spark control computer . whats it look like ?
slant six's RULE!
PostPosted: Wed Feb 20, 2008 11:02 pm
I am pretty sure it's tucked in the left inner fender behind the battery.
PostPosted: Thu Feb 21, 2008 9:54 am
yep...just where u said it was... 4289603
Im thinking it's the canaster's charcoal...I put 2 bottels on 2 fill ups of rubbing achoal 90%. i always do this on old vehicles that sit. Im thinking the charcoal has fe'd the carb..read a post while searching here on that happening...we c..
slant six's RULE!
PostPosted: Sat Mar 01, 2008 9:05 pm
put rebuild carb on runs great !
slant six's RULE!
Users browsing this forum: Ahrefs [Bot] and 5 guests
