It is currently Fri Nov 20, 2026 4:46 pm
PostPosted: Thu Feb 21, 2008 5:33 pm
I am rebuilding a 1973 225 and was wondering how you prime the engine with oil before the first start up. In the past with fords and chevys I have used a drill with a some square stock to prime the engine. Is there a way to do this on a slant six by turnin the camshaft or something.
Thanks Joe :shock:
PostPosted: Thu Feb 21, 2008 5:41 pm
Most guys just lightly pack the pump cavity with vaseline. Then you can crank the engine with the plugs removed to get oil circulating. Just be sure your battery is fully charged.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Feb 21, 2008 6:49 pm
Remove valve cover and pour at least one of the quarts of oil you're using all over the valve train in addition to turning over without plugs
PostPosted: Fri Feb 22, 2008 12:58 pm
Fill the Filter 3/4 of the way with oil before putting it on the pump before the first startup that helps too.
PostPosted: Fri Feb 22, 2008 5:10 pm
if you really wanna be hardcore and get good psi, u can use an ol crappy spray gun and attach a hose to the end and hook it up to the sender unit... fill gun wit oil, and let er rip.... u got oil pressure
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 5 guests
