It is currently Tue Dec 30, 2025 9:59 pm
 Post subject: How to clean carbon
PostPosted: Thu Feb 21, 2008 3:19 pm
Ok guys
How do you clean the carbon out of a exhaust port and the Valves. I have the head torn down for maint.
It has to be something I can do.
I live 1.5 hours from the closest machine shop and I dont have a tank.
I did get muratic acid and soak the head a couple of hours and that helped.
Just dont want to mess up the guides.
A friend sugested spray gasket remover...any ideas.
Thanks
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Feb 21, 2008 4:17 pm
Zep Industrial Purple degreaser from Home Depot.
PostPosted: Thu Feb 21, 2008 7:06 pm
hi, do you have a napa or parts place that has carb cleaner in a 5 gallon pail? pick up a pail and dunk everything including rocker shaft and rockers. very important to make sure everything is clean and oil passages are open. you can clean everything at your own place and its still cheaper than paying someone to do it. ron
PostPosted: Thu Feb 21, 2008 9:59 pm
I had bad carbon build up on my valves, I used oven cleaner. Valves were out of the head, though.
Excuse me, does this smell like chloroform to you?
PostPosted: Fri Feb 22, 2008 7:29 am
Good Ideas keep them comming Ill try some of these today.
Thanks
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Feb 22, 2008 8:12 am
Purple Power for oily deposits. Wire brush on a drill motor for caked on carbon.
PostPosted: Fri Feb 22, 2008 8:43 am
A sand blaster or bead blaster makes fast work out of carbon deposits.
PostPosted: Fri Feb 22, 2008 11:01 am
Ain't that the truth! It also makes fast work of your hands if you discover a big hole in the gloves......the painful way :evil:
