It is currently Sun Feb 23, 2025 10:57 am
 Post subject: Electric Water Pump
PostPosted: Sat Feb 23, 2008 3:50 pm
Is there any such thing for the slant? Trying to round up some parts for next build and if there around thought it might be a cheaper purchase. So Electric Water pump, or can we convert one from a 350 and such to a slanter?
PostPosted: Sat Feb 23, 2008 4:01 pm
I have a sbc electric w/p.....it is not ever going to work with a slant.
You can use a Moroso Water pump kit to make the slant pump electric. Dennis Slantzilla has one...and I think CharlieS. That would be the easy way....
PostPosted: Sat Feb 23, 2008 5:12 pm
Sounds good that was what I was thinking might happen. I just plan on adapting something from a cheap source ie sbc and putting it on the slant somehow. Thanks again. Wes
PostPosted: Sat Feb 23, 2008 5:14 pm
Remember that older slants don't have much alternator power.............
PostPosted: Sat Feb 23, 2008 5:16 pm
You want this:
Moroso 63750 $82.95
PostPosted: Sat Feb 23, 2008 5:44 pm
6 Pack Dart
I will post a
picture of the bracket I made to fit the waterpump.
http://s77.photobucket.com/albums/j59/r ... racket.jpg
PostPosted: Sat Feb 23, 2008 7:17 pm
http://www.jegs.com/p/Stewart+Component ... 2/-1/10135
PostPosted: Sat Feb 23, 2008 7:49 pm
Now that's interesting. I've never seen an electric in-line water pump like that before. I wonder how the 55gph max compares to the throughflow achieved with a stock slant-6 pump (and at what RPM).
PostPosted: Sat Feb 23, 2008 7:56 pm
I have a Moroso electric fan and water pump drive on my car. It cooled fine, even in street use. It is not recommended for street car, only race cars. The motor is actually a heater blower motor, and has bronze bushings. These are not designed for the side loading a belt puts on the bearing. They are also not designed for the amount of torque required to run the fan and water pump. In street use the motor will run very hot, and can burn out the windings, after awhile. If the windings last, the bearings won't. In occasional street use, I needed to replace the motor,about every 6 months.
PostPosted: Sat Feb 23, 2008 8:33 pm
Seems like this in-line design would eliminate those problems, no?
PostPosted: Sun Feb 24, 2008 5:33 am
Yes, but that is just the water pump. Still have to get an electric fan. Look at the price of that inline pump. Not much bang for the buck. Don't feel it is worth spending that much money on a street car, for the small amount of gain. On a race car the Moroso unit works/lives just fine.
PostPosted: Sun Feb 24, 2008 6:20 am
I make sure to run the drive belt very loose on mine. I know someone who used to eat motors on a BB Dart race car. Problem went away when he quit tightening the belt like a regular fan belt.
I honestly haven't run mine enough to know if it does anything one way or the other.
I did find out last year that when I shut off the nitrous and 2 step after the stripe, do not shut off the 3rd switch for the water pump. :?
PostPosted: Sun Feb 24, 2008 7:07 am
Is there even much to gain in lost HP by converting to an electric water pump? I was under the impression that the stock pump hardly put any draw on the engine as opposed to a belt driven fan, which can suck up quite a bit of HP.
PostPosted: Sun Feb 24, 2008 8:32 am
On my mudbogger I saved almost 100lbs by going from a cast iron W/p and Saginaw power steering to a Proform aluminum elec w/p and manual R+P steering.
Two things make the electric water pump worthwhile......better cooling at an idle...and at WOT. The side benefit is reduced power loss at WOT.
Typically I start the car....wait till the heads are warm and start the pump.....the electric fan starts at the same time. I make a run.....fight my way back to the pits, shut down the motor and leave the pump running till everything is warm(not exploding hot).
I dont run an alternator.
Drivability in the pits and staging are much improved. If there is a delay in staging I can shut down the motor and leave the pump on instead of appearing at the line overheated and tempermental.
The Proform pump weighs 6 lbs ....has no belts and is a snap to install. It wont work on a slant. A clever guy could build slant specific integeral electric pumps.
PostPosted: Sun Feb 24, 2008 9:12 am
Wow, this relates to a new SL6 product design I did a number of years ago. Basically it's a aluminum water pump housing that accepts the BB Mopar water pump assembly. (my design was a machined casting but a billet one is also possible)
The problem I found was that this new "stack" of parts stuck-out further from the engine block and could interfer with the radiator.
I was working to resolve that issue but the project fell way low on the "to do" list.
To have a special WP housing that allowed BB / Hemi pumps to bolt-on and maintain good spacing would allow use of OTS Hemi electric pumps currently available.
Users browsing this forum: Semrush [Bot] and 47 guests
