It is currently Fri Nov 20, 2026 5:34 am
 Post subject: rear main seal
PostPosted: Sat Feb 23, 2008 10:11 pm
I have replaced the rear main seal on my van twice, and it still leaks. Is there any speedy sleeve for this 1979 slant 6 or another kind of seal that works better? has any one else had this problem?
1979 dodge sportsmen camper van
PostPosted: Sun Feb 24, 2008 5:54 am
Hi Kit,
In a hurried moment I almost put one of the seals in backwards once. VERY easy to do, are you certain the lip is pointing the right way? I ask cause I have never had one fail.....oh did you also use a torque wrench to tighten the aluminum seal block under the crank rather than guess at if it was tight enough? It's more important than many torques..
rock
'64d100
