It is currently Mon Nov 30, 2026 1:41 am
 Post subject: Trankenstein
PostPosted: Tue Feb 26, 2008 7:35 pm
Car Model: 1974 W100; 72 Dart
I have a working 998 tranny from behind a 318. It was rebuilt less than 2K miles ago. It is the lock up type of course. Can I take all the guts out of it and put them into a 904 from a 75 Dart to make a slant proof tranny?
Can I use the input shaft from the older tranny so I can get a higher stall convertor more affordably? I assume I would need to use the older style front pump and valve body as well if I did not use the lock up TC?
Thoughts?
sb
PostPosted: Tue Feb 26, 2008 8:27 pm
i assume you can from my reading as the later is a OD trans where the 904 isnt. you need to have that notch on the back of the trans for the OD gear. if you manage to make it fit, then i will be right behind you! add a shift kit to that with a OD trans in the 904. i would be a happy camper!
from what i have been reading though you cant get any tougher stock then a 904. as i read on forabiodies.com the latter a500/a998 were just not as strong stock.
1976 Plymouth Feather Duster
2002 Dodge Dakota 4.7l v8
PostPosted: Wed Feb 27, 2008 4:46 am
The a-998, and a-999 are not overdrive transmissions. The a-500, and a-508 are. The designation A-998, is heavier duty versions of the A-904, with more clutches, and a heavier band. The A-999 is "beefed" even more, for use with the 360 engine. I am not sure what needs to be done, to convert a lockup to non lockup, or vice/versa.
 Post subject: worst case scenario
PostPosted: Wed Feb 27, 2008 6:15 am
I guess in the worst case I would just put all the insides of the 998 into the 904 case. I was just hoping to get the bigger clutch pack with the 27 spline input shaft.
sb
PostPosted: Wed Feb 27, 2008 6:45 am
You can use the drums to get more clutches, but not the input. The input on a lockup is different than a non lockup and will not work. The lockup will also not work in a 904 case because some of the oil passages are not there.
 Post subject: alright
PostPosted: Wed Feb 27, 2008 8:51 am
Cool! That is the info I was looking for!
sb
PostPosted: Wed Feb 27, 2008 9:27 am
The 2.74 low gear set from the lock up 904 will go in.
Using your front pump and input shaft will allow the 5 clutch front drum to work, but will need machining on the pump and the front drum for everything to fit.
Slant Cecil
PostPosted: Thu Jul 31, 2008 12:43 pm
The slant six was available with the lockup converter just like the 318 powered stuff was right?? What year would I need to get the lockup tranny stuff from? 78-81? or so??
I want to put the lockup trans in my '73 duster or would it even be worth doing??
PostPosted: Thu Jul 31, 2008 1:56 pm
Can you go with a lock up converter on a 904?
and achieve better mileage?
PostPosted: Thu Jul 31, 2008 7:35 pm
IIRC, the lock-up started in '78.
Ted, the lock-up will work on a Slant, but you have to have the whole transmission. You can't just stick a lock-up converter in a regular trans.
PostPosted: Thu Jul 31, 2008 8:08 pm
So pretty much I need to get a slant tranny and converter from a 78 to 80ish car??
PostPosted: Fri Aug 01, 2008 6:29 am
they put /6s in cars til 83, and trucks and vans til 87 so that gives you a little wider year-range to pick from, than you think. And yes, the lockup started in 78 but being 1st-year, not all 78s had L/U.
Users browsing this forum: Amazon [Bot] and 1 guest
