It is currently Sun May 17, 2026 6:01 pm
PostPosted: Thu Mar 06, 2008 4:10 pm
Can you identify this set up, what is it, what is it worth, what all additional parts would I need to hook it up, and should I get it for my 198?
Just because you are not "paranoid" doesn't mean they aren't coming for you.
PostPosted: Thu Mar 06, 2008 4:54 pm
Looks like a pretty clean adaptation of a Weber 2bbl carb onto a 2-piece EB-welded aluminum intake, complete with suitably adapted air cleaner. I've never run one of these carbs, but I bet it could be made to work well. You'd likely need to do some throttle linkage adaptation, particularly if your car has an automatic transmission.
PostPosted: Thu Mar 06, 2008 5:28 pm
I've got a three on the tree manual.
PostPosted: Thu Mar 06, 2008 8:53 pm
You'll like this weber very much. :)
Parts plentiful and jets available. If yoiu discover needs tuning get air/fuel gauge and a O2 sensor. Narrowband is ok, but wideband is excellent but spendy as it's a complete kit by about 2x than narrowband.
Cheers, Wizard
PostPosted: Fri Mar 07, 2008 8:42 am
Oooooohhhh a Weber. Looks like whoever put that together knew what they were doing. I'd love to try a 2BBL Weber for a Super Six setup...
Adapting the linkage shouldn't be too difficult if you know how to rig up a control cable.
