It is currently Wed May 20, 2026 5:00 pm
Post new topic  Reply to topic  [ 95 posts ]  Go to page Previous 1 2 3 4 57 Next
PostPosted: Tue Mar 11, 2008 8:03 am
Can some one scare up some pics of slant pressure plates for me? Spec is asking for them.
The Engineer there is being really helpful, and I may have something to report soon.
PostPosted: Tue Mar 11, 2008 9:32 am
Greg,
PM me your email and I'll send you a pic or few. Might take me a week since I'm travelling. PM me again if I forget.
PostPosted: Tue Mar 11, 2008 12:35 pm
I could have done that last week......
PostPosted: Tue Mar 11, 2008 12:58 pm
Sandy, do you have part numbers or other cross referenceable info? That would help.
PostPosted: Tue Mar 11, 2008 5:36 pm
Greg...I have a stock 9" flywheel + pressure plate and T/o bearing. The disc is a 9 1/8 unit from McLeod I bought on Ebay...they subbed in a ceramic disc when the kevlar one I bought was not available. I have a Ford 5 speed so the disc is for a Taurus SHO or Turbo Tbird Coupe.
Have a look on the mcLeod site...there is some good stuff...including 10 "units they say are NOT for performance use.
 Post subject: 9" PRESSURE PLATE PICS
PostPosted: Thu Mar 13, 2008 9:47 pm
Here are some 9.25 PP Pics.
This is a multiple bolt pattern parts store unit.
PostPosted: Sat Mar 15, 2008 7:53 am
Thanks Greg and Lou. I will send them on to the Spec Engineer, and see what he says.
 Post subject: update
PostPosted: Mon May 19, 2008 9:04 pm
They are working out a special 10" slant six/T5 combo right now for us. The engineer I have been working with, Matt, is checking out mopar/chev/ford/Nissan 10 inch pressure plates, specifically to find a modern diaphragm style PP that will work for us.
The prices seem reasonable, and more than competitive. Matt's goal is to come up with a part number for this combo, so that anybody else can easily replicate the package.
I will let you all know more in about a week.
 Post subject: Nice Work
PostPosted: Tue May 20, 2008 7:27 pm
Greg, Keep Up the good Work!
Everyone that rows their slant will surely appreciate your time and efforts!
PostPosted: Wed May 21, 2008 3:49 am
Sounds great, Greg. Keep us posted.
 Post subject: Results-- Very positive!
PostPosted: Sat May 31, 2008 10:28 am
Hi all,
So, I have been working with Matt at SPEC clutches over the last couple of months. I needed a mustang disk ( or a custom disk with a T5 hub) and a pressure plate that would fit our flywheel. I got a 300 ft/lbs custom kit from them, and in initial fit testing, the clutch is working very well.
The clutch disk has kevlar friction surfaces
The pressure plate is a modern diaphragm style, and will work with the standard T5/mustang diameter TO bearing
This is a 9" clutch, and weighs a lot less than the 10", but should have the same or better holding power.
Matt has talked to me about offering this whole thing as a single part number, either with the ford style clutch disk hub, or a mopar one. We decided to wait until we test it all out on my car. If this works, it should be easy to order your own.
I will keep updating this thread as more is learned. Thanks to Lou and Menko for helping out.
PostPosted: Sat May 31, 2008 11:09 am
Very cool Greg!
Its interesting we ended up with a 9" clutch on this.
My pieced together clutch is also 9"...I used a McLeod disc for a Taurus SHO (9") with a stock PP.....it seems very good so far. I originally ordered a Kevlar disc but McLeod subbed in a ceramic disc.
I certainly agree a 9" weighs a ton less than the 10"
It always seemed to me the 10" mopar setup was an afterthought .....kinda sorta modded to work on the slant.
Is that a 10 spline disc?
Good work Dude!
PostPosted: Sat May 31, 2008 11:25 am
yup, 10 spline disk here. They are willing to do a mopar splined disk as well, for 833 applications.
Thanks for the compliment, Sandy. Considering your pioneering efforts, we couldn't have done this without you.
I don't know how many 273 cars with the 122 tooth flywheels are left, but this would help them as well.
PostPosted: Tue Jun 10, 2008 9:52 am
Does this pressure plate have a steel ring instead of a cast ring ?
I wander if they will make one that holds more power than this, like a 500ftlb setup ?
Nice looking clutch, its good to see companies willing to help.
A stick setup will be going in mine soon as I get the tranny built. I have a new 9" setup already but its nothing special.
Jess
PostPosted: Tue Jun 10, 2008 10:47 am
Does anyone care that the friction material pictured does not appear to be Kevlar? Spec Clutch's Kevlar material is tan. The organic material is pictured in Greg's post.
