It is currently Sun May 31, 2026 12:35 am
 Post subject: power brakes
PostPosted: Thu Mar 13, 2008 6:49 am
Hi and thanks for admitting me.
I greatly appreciate if anybody can answer my questions. Mine is a Plymouth Duster 1973, A body, slant 6 225 engine, drums in the four wheels, 1) Did it ever a 73 Duster like this had power booster brakes? 2) If they weren't, which of the ones in the market (from Cardone, etc) is easier to adapt to it?
DM_duster
PostPosted: Thu Mar 13, 2008 9:07 am
Welcome to the board. The 73 Dusters were available with power brakes and disc brakes as options. The disc brakes are called Kelsey Hayes and are 4 pistons type. They are also getting hard to find. The option that most people are chosing is to upgrade to the Large Bolt Pattern LBP discs from 74 and up A-bodys. With Power boosters and Master Cylinders from auto parts stores buy NEW and not reconditioned. I hope this gives you some ideas and feel free to ask more questions.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: Power brakes
PostPosted: Thu Mar 13, 2008 9:16 am
Thanks and pardon my ignorance, but apparently there can not be such a thing as power brakes and drums in the four wheels, or can it be?
DM_DUSTER
PostPosted: Thu Mar 13, 2008 10:22 am
This is off by one year. 1972 was the last year for the 4-piston disc brakes on A-bodies; 1973 was the first year for the single-piston disc brakes with the large (4½") wheel bolt pattern.
 Post subject: Re: Power brakes
PostPosted: Thu Mar 13, 2008 10:26 am
Yep, power 4-wheel drum brakes were available.
What is your goal? Do you have something specific in mind that you're trying to achieve? The nonpower drum brakes do not require a lot of foot pressure when they are in proper repair, so if you are having to stand on the brake pedal to get the car to slow down, the first thing to do is to inspect, diagnose, and repair the brakes, rather than thinking in terms of retrofitting a booster.
 Post subject: Power Brakes
PostPosted: Thu Mar 13, 2008 11:11 am
Honestly, I feel tempted with a power brakes booster on sale on ebay now. Apparently it comes from an A-body. Though I like to preserve my Duster as much as close to original, if I can add a litle more with the power brakes with no major changes I would do it. Thank you for the good reception to my questions.
DM_DUSTER
PostPosted: Thu Mar 13, 2008 11:25 am
I'm trying to put a picture of what I'm looking for.
[/img]
PostPosted: Thu Mar 13, 2008 11:38 am
A power booster would decrease the pedal effort, but would not add stopping power.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Thu Mar 13, 2008 2:00 pm
i just did the disc swap... and i can say that the power booster setup is a PITA unless the booster is in perfect condition, even then i think i would rather have manual disc. i used that power booster for about a week. its not really worth it...
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
