It is currently Sat Nov 21, 2026 1:49 pm
 Post subject: bad hydrolic lifter
PostPosted: Sun Mar 16, 2008 3:51 pm
our 1985 dodge ram 100 had old leaking cork valve cover gasket so when I put a new felpro valve cover gasket on, I notice I had non adjustable rocker arms. and that one was lose and clicking. also i notice 3 push rods were'ny oiling..any thoughts how to repair ?
slant six's RULE!
http://www.usajon.com
PostPosted: Sun Mar 16, 2008 4:06 pm
Online
Check the rockers, the lifters/pushrods oil from the top down. :D
PostPosted: Sun Mar 16, 2008 4:52 pm
i'm thinking i have a slightly colisped lifter..and a few clogged pushrods..we have put 6K miles on it since the valve cover job...
slant six's RULE!
PostPosted: Sun Mar 16, 2008 5:00 pm
The oiling path is though the rear rocker shaft standoff, the rocker shaft, rockers, the down through the pushrods. A clooged pushrod or rocker with prevent oil reaching the lifter. If the lifter doesn't get oil it will collapse.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Mar 16, 2008 6:19 pm
I find the rockers stopped up most of the time this happens, a good cleaning and things return back to normal.
Jess
 Post subject: Same deal?
PostPosted: Tue Mar 18, 2008 7:18 am
I have this problem on my other, non-SLANT 6, A-body with the hyd. cam adj rocker 340 (1971). Does anyone know if this oils through the rocker arm similarly, or should I just go to 'wrongplacetoask.com' :oops:
PostPosted: Tue Mar 18, 2008 7:23 am
Online
340 oils the rockers through the shaft. The pushrods are solid, no oil comes up through them. (or goes down) :D
PostPosted: Tue Mar 18, 2008 8:30 am
Thanks, Slantzilla. I'll start with the rockers.
PostPosted: Tue Mar 25, 2008 9:19 pm
Jess
whats the pro way to remove the rocker shaft. I sure don't want to drop anything into the internals..
slant six's RULE!
PostPosted: Tue Mar 25, 2008 9:27 pm
You just described the Pro way. Don't drop anything! It's pretty easy really. Loosen each bolt a turn or so at a time until they are free. I get away with then lifting the whole assembly off the head with the bolts still resting in the shaft. Haven't lost anything down an engine yet.
PostPosted: Sun Apr 20, 2008 11:30 am
well i took the rockarm assembly apart. some of the rear ones were carboned pretty bad..aprox 2.5 hour job to remove clean replace..oil change / still a tappin...looks like a bad lifter as when I check rocker arms and pushrod tubes they all flowed through their holes/ports.
HOW do you take out the old lifters and replace with NEW ones without removing the head... A special tool ? just wondering...thanks
slant six's RULE!
 Post subject: Woof...
PostPosted: Sun Apr 20, 2008 1:46 pm
on the 1975-1987 heads you have to remove the head, the holes aren't big enough to pull the lifters through like the earlier drool tube heads...
-D.idiot
Users browsing this forum: Amazon [Bot], Google [Bot] and 6 guests
