It is currently Sun Jun 07, 2026 4:48 pm
PostPosted: Sun Mar 16, 2008 7:11 am
Ok guys
I've found my super six setup, carb, intake manifold, even the super six logo on the aircleaner, oh and the step down linkage. What was missing was the exhaust manifold. Will my stock non-super six exhaust manifold work?? By the way paid $80 for the whole works for another $45 He'll through in the exhaust manifold if he has one.
This is on a 71 dodge demon.
Thanks guys and gals
Jeff
If you always do what you've always done, you always get what you always got.
PostPosted: Sun Mar 16, 2008 7:14 am
Nope same one. Great price!!!
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
There is no difference in the exhaust manifold on a Super 6 vs. a 1 bbl engine. Use the one you have if it's in good condition.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Mar 16, 2008 9:44 am
can't wait to try her out with Super 6, thanks for the info .
PostPosted: Sun Mar 16, 2008 11:15 am
There is a difference between early and late manifolds. The choke pocket changed when they went to the electric choke around '74 or so. The rest of the manifold is unchanged.
SS setup will be for the electric choke and the older watchspring choke may not work with it. :shock:
PostPosted: Sun Mar 16, 2008 11:28 am
Yep, the differences in exhaust manifolds are by year, not by carburetor type. The factory 2bbl choke thermostat definitely won't fit a '70-'72 exhaust manifold (with open "stove" sealed at the top by a gasketed stainless steel cup, instead of one of the three types of cast-in choke pocket used in '60-'65, '66-'69, and '73-up). No big loss; the electric choke kit will bolt on and work better anyhow.
PostPosted: Sun Mar 16, 2008 2:22 pm
Thanks SSD, I knew there was something with the choke, But like you said I'm going electric anyway, besides I have the whole intake, It's the exhaust manifold I was worried about.
Thanks.
PostPosted: Sun Mar 16, 2008 5:35 pm
i do love the versatility of my manual choke. i can give it a lil boost on accel when mornin cold big hill bog comes in...
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
PostPosted: Sat Mar 22, 2008 7:12 pm
so if the super setup used a 2.25 exhaust pipe is there no difference in the outlet of the manifolds? - oo3
PostPosted: Sat Mar 22, 2008 8:28 pm
Correct! stock is 2". You can enlarge them to 2.25".
I did on mine with a long cutter and a long sanding mandrel from a vertical wood working sander.
PostPosted: Sun Mar 30, 2008 8:30 am
I have the super 6 intake off a 1970 225 cu in.
Will my 1961 170 cu in exhaust manifold work as a mate? Do they share the same exhaust chamber and same outlet size? OK to use?
(I will be using manual choke) gl/6
PostPosted: Sun Mar 30, 2008 9:53 am
Yes, it is ok to use. All exhaust manifolds are interchangeable and have the same 2" outlet size. They also can be ground or sanded out internally to 2.25".
Super six intake manifolds with the two barrel came out in 1976 and 1977 on Volare's and Aspen's.
 Post subject: do urself a favor. . . .
Car Model: 1968 A108 225/3 on the tree
get the most out of ur new SSix. get headers or the Dutra duals for ur exhaust manifold. if u don't, u'll always be wondering, "what if?"
D~~~!
68 A108
73 Harley Servicar
71 BMW R75/5
48 Indian Chief
2003 Ford Ranger XLT extra cab
1997 Geo tracker(Suzuki Sidekick)
PostPosted: Sun Mar 30, 2008 10:14 am
Just before I put this project on hold a couple years ago, I thought I saw an article on how to split your own? I thought it was written by Doug?
Also on the 1970 = years vs super six, I wrote it down wrong. My bad. :roll:
PostPosted: Sun Mar 30, 2008 11:29 am
Got to articles section on the first page for Doctor Dodges article.
Dutra Dual Exhaust Rear Manifold Modification Procedure
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
