It is currently Sat Oct 10, 2026 2:21 am
PostPosted: Mon Mar 24, 2008 10:41 am
Location: La Milesse FRANCE near the 24 hours of Le Mans
I'm french, and i'm going to upgrade my dart 270 four door sedan with 170 ci slant, automatic transmission.
I've bought clifford intake manifold , and i would like to connect a holley 390 cfm throttle to the pedal.
I saw that we can do that with lokar linkage, but what about the pedal system ? Do i change my pedal ?
Thanks
Mat[/img]
Dodge dart 270 four door sedan with 170 ci slant.
Video post you tube dodge dart 1965
 Post subject: Pedal Linkage for 390
PostPosted: Mon Mar 24, 2008 2:13 pm
The stock pedal connects to the Lokar linkage just fine.
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
 Post subject: Something like that...
PostPosted: Mon Mar 24, 2008 6:01 pm
He's got the old ball/crank pedal, the cable pedal would be out of a 1965-66 with the V-8, or he could possibly use a later pedal assembly, and drill the holes in the firewall to make things work... (there's always a way to make it work, but it sometimes doesn't look good...)
-D.idiot
PostPosted: Mon Mar 24, 2008 8:05 pm
Hi prattwhitney,
When I put on both my Edyy 500 cfm and my current Holley 390 cfm I had to go with what I am sure is called a ball and crank linkage. It is a rod not a cable, regardless. Mine was stock on my 64 truck on a 1bbl carb. Taking it off for a 4 bbl offy manifold gave me 2 choices: primaries parallel to or perpendicular to the cylinder line. I studied the matter, bought a cable assembly and pedal, and still couldn't see a clean easy way to use a cable. So I went back to rod linkage. It was really easy. All I had to do was lengthen the rod by adding in one of the hexagonal connectors for threaded rods that are threaded inside each end. I then threaded the end of the rod that has the stud for the throttle linkage hole.( It takes larger washers to secure the stud in the hole) It seems to me I had to bend both the rod in the engine area and I had to cut a piece of the curl off the rod where it meets the pedal, and bend that rod over to the right. I just held up a dummy rod tothe carb and worked it back and forth to to get the right length, then screwed the adapter in between the two rod pieces, one coming up from the firewall and the one from the carb. I can send you a pic if yo want, it was really easy. I never did figure out how to get a cable assembly to work the throttle though. When I added the automatic tranny I used a BPE kickdown cable though, Good company, good stuff.
rock
'64d100
PostPosted: Tue Mar 25, 2008 1:53 am
Hi guys and thanks for your answers.
From France where slant are discredited to benefit of V8, i think that upgrading slant is a proof of technical interest and economy ( 1.35euros per liter of gas !), and i'm most grateful to your for your quickly answers.
Regarding to your answers, my car has the old ball/crank pedal as Dusteridiot said. I was thinking at removing the pedal and put later pedal assembly. But i prefer the idea of lengthening the rod ,as you've done Rock.
In additional of your post, a couple of pictures will be helpful.
Thanks
Prattwithney
Users browsing this forum: Amazon [Bot] and 16 guests
