It is currently Tue Nov 24, 2026 7:38 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Sun Apr 06, 2008 6:43 am
Most carbs have an internal vent like this. It's supposed to be there, and is not at all comparable to running the external vent to the air cleaner.
PostPosted: Sun Apr 06, 2008 3:28 pm
I have seen cars where the fuel bowl vent was connected to the gas tank return line.
Hey Ted,
That is a perfectly fine thing to do, and it's common practice (i've seen several). Since the fuel return line isn't pressurized when the car is OFF it vents just fine.
PostPosted: Sun Apr 06, 2008 5:50 pm
Hey Ted,
Just because you don't understand why something's a bad idea and have seen other people do it because they don't understand it either, doesn't make it a perfectly fine thing to do.
PostPosted: Sun Apr 06, 2008 6:04 pm
Dan, what are some options :?: :?: :?: :?: :?:
After you suggest some alternatives from the stock fuel vapor system like you did with the ignition HEI mod,
where can you buy a new filter and new charcoal refill or a complete new canister?
Please list part numbers and automotive contacts where parts can be purchased.
Thanks :!:
Last edited by Aggressive Ted on Sun Apr 06, 2008 6:46 pm, edited 1 time in total.
PostPosted: Sun Apr 06, 2008 6:38 pm
Need I say more?
Users browsing this forum: DuckDuckGo [Bot] and 5 guests
