It is currently Thu Nov 26, 2026 12:55 pm
PostPosted: Fri Apr 18, 2008 3:44 pm
Contributor
PostPosted: Fri Apr 18, 2008 6:58 pm
Wow, that's an interesting one. I'm tempted to think it's a (very) bad wheel bearing...maybe...?
PostPosted: Fri Apr 18, 2008 7:29 pm
Contributor
Wheel bearings are nearly new, with no visible damage or wear, and no noise when I drove it a week ago.
PostPosted: Sat Apr 19, 2008 4:16 am
would an incorrect installation of the primary vs. secondary shoe have such a spectacular effect? but you've been driving it on the same breaks before this started, right?
PostPosted: Sat Apr 19, 2008 8:49 am
Im with Dan on this. Even though the wheel bearings were replaced 1000 miles ago IT REALLY sounds like a wheel bearing. There are alot of Cheap bearings out now but even a good brand can have a problem.
My02.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sat Apr 19, 2008 10:22 am
Should be fairly easy to check...slack off the wheel bearing preload adjustment such that the drum stays in place but isn't locked down by the nut , and see if the behaviour changes from "wheel won't turn" to "wheel keeps turning but bearing obviously seizes".
PostPosted: Sat Apr 19, 2008 10:46 am
Contributor
After checking everything again, I have to agree that the bearing is the only logical answer. I ordered a new set from Rock Auto and will get the drum turned before I install them. At least I'll know that the wheel and drum are stable and turning true.
A side note...I was going to order a new drum, and discovered that they had drums for both 2" and 2-1/2" brakes for a Valiant with the slant engine. I thought they were all the same.
Mine are 2-1/2", but that drum isn't stocked, and the note said it could be up to 31 days to get it, so I'lll use the old drum for now.
PostPosted: Sat Apr 19, 2008 11:01 am
The fronts are 9″× 2½″. The rears are 9″× 2″. If you're keeping the 9″drums, it's best to use the much meatier 70-'72 finned drums, which give you a bigger margin of heat rejection before the brakes start fading. See this post.
PostPosted: Wed Apr 23, 2008 6:07 pm
Contributor
Update for anyone interested.
I had the drum turned, and it was within FSM tolerance, according to the machine shop.
Good old Rock Auto came through again with a quick delivery and the right part numbers. Unfortunately, both bearings were made in China. The seal was USA made, but I sure wish it had been the other way around.
I cleaned up the old bearings and gave them a close inspection. There was a very slight discoloration that was apparently caused by overheating. I also found that the outer bearing cage had a tiny deformed area on one side. It wasn't enough to bind aroller, but it might have contributed to the problem. FWIW, the bearings I removed were made in Romania.
Compared to some bad front wheel bearings I've seen, the ones I removed looked pretty good, and they never made any noise. However, something caused them to get hot enough to discolor the metal.
After adjusting the brake, I took it for a short test drive, and the problem did not reappear, but we'll see what happens.
PostPosted: Wed Apr 23, 2008 7:13 pm
Car Model: 63 Dart 81 D150
Turning just one drum is a bad idea. If the front drums are more then 0.010" difference in diameter the car can pull to the larger side under heavy braking.
TopHat
PostPosted: Wed Apr 23, 2008 8:46 pm
Contributor
TopHat
The drum was only turned enough to determine if there was an out-of-round condition, but FWIW, finding a forty-year-old car with drums within .010" of each other has about the same odds as winning the lottery.
Users browsing this forum: Bing [Bot] and 9 guests
