It is currently Mon Nov 16, 2026 12:05 am
 Post subject: Rear end lube plug....?
PostPosted: Sun Apr 20, 2008 9:33 pm
Decided today to check the lube level in my 7-1/4" rear end, but the plug in the cover has a rather large 12 point hole of some kind in it. Never seen this before. All others I've seen have a square hole that you can put a 1/2" drive into. Is there a special tool for this, or will something else work?
Thanks!
________
Maryjane
PostPosted: Sun Apr 20, 2008 9:43 pm
Same 1/2" square tool, but a double square plug.
PostPosted: Sun Apr 20, 2008 10:50 pm
I think a double square would have 8 points.....right? This one has 12, but I'll try the 1/2 drive.
________
Com?te
PostPosted: Mon Apr 21, 2008 8:57 am
Either that or a piece of ½" bar stock from the hardware store.
PostPosted: Mon Apr 21, 2008 12:30 pm
I guess that makes it a "triple square" socket head plug... it still takes the same 1/2 inch drive tool. :D
