It is currently Fri Nov 20, 2026 7:34 pm
 Post subject: Does anyone remember
PostPosted: Mon Apr 21, 2008 11:04 am
A friend of my dads say there was a bracket that held up the exhaust on a slant six to keep the manifold from cracking and said without it it would possible crack so anyone know what im talking about if so got a pic of one would be nice to seee?
1972 Plymouth Duster 225 Super Six Slant
PostPosted: Mon Apr 21, 2008 11:26 am
Car Model: 1974 W100; 72 Dart
Usually the exhaust manifold cracks from being torqued down too tight, thus keeping it from being able to expand and contract with heating/cooling cycles.
As far as a bracket that holds it up? :?:
Maybe someone else has some input.
sb
PostPosted: Mon Apr 21, 2008 11:32 am
I have seen what you are talking about and have seen it on different Chrysler RWD models regardless of engine on cars new enuf to have a catalytic converter, because of th extra weight they bring to the ex. system.
PostPosted: Mon Apr 21, 2008 11:38 am
It's a simple metal strap with a quarter-twist in it. The top bolts to one of the engine-to-bellhousing bolts, and the bottom has two holes spaced to receive an ordinary exhaust pipe U-clamp. This supports the exhaust pipe so as to relieve the pipe-to-manifold junction of some of the stress.
PostPosted: Mon Apr 21, 2008 11:53 am
I've seen that. Didn't even think of that from the OP's question. I was imagining some huge metal bracket on the engine cradling the manifold! :oops:
PostPosted: Mon Apr 21, 2008 11:56 am
lol welll me and dad where gonna fasion a braket for it
PostPosted: Mon Apr 21, 2008 1:33 pm
Be sure and make it to where it does go to the bellhousing, trans, or engine block. In other words dont hook it to the body/frame in anyway. That would cause stress and even transmit vibration to the passager compartment.
Jess
PostPosted: Mon Apr 21, 2008 1:35 pm
got ya jess
 Post subject: Yep...
PostPosted: Mon Apr 21, 2008 2:22 pm
There are two versions of the bracket...
On the 70's cars up to 1975 it's attached to the tranny bellhousing and has a simple loop... with the advent of the catalytic convertor and the 'two' pipe system (the header from the manifold to the tranny crossmember, and the 'rest of the exhaust pipe' with the cat and muffler... there is an added bracket just past the cat. convertor that attaches to the tranny crossmember drivers side bolts...
Afterupsizing pipes I've never used either, and I've only used the manifold 'kickstand' on the hyperpak as a just incase...
I probably have a couple of those laying in a bin someplace... the 1973-1974 version is like 1/4" plate and a slot for the round pipe bracket and bolt.
PostPosted: Tue Apr 22, 2008 10:41 am
According to my '71 shop manual, the support is used only in fleet (read police and taxi) vehicals equiped with the 225. Cant find my '72 manual, but I assume it says the same. Just FYI.
Edit: Its only on the B body where the pipe runs under the passenger side of the engine.
PostPosted: Tue Apr 22, 2008 12:13 pm
does anyone has a picture of this bracket
Users browsing this forum: DuckDuckGo [Bot] and 4 guests
