It is currently Tue Nov 17, 2026 5:42 am
PostPosted: Tue Apr 03, 2007 8:08 pm
when i pulled the studs out of my head, most were seized pretty badly. some got pretty boogered up, and 2 broke off and i had to drill them and use e-z outs to get em out. i want to go ahead and replace all of the studs. where is the best source for these, part no. etc?
russ
PostPosted: Tue Apr 03, 2007 8:35 pm
See here
PostPosted: Wed Apr 04, 2007 4:53 pm
thanks for the reply. when i went to the dorman webpage, it said i had to register to be able to purchase those. when i tried to register it wanted an account number. is there a way around this? or does anyone have a part number for another store?
thanks
russ
PostPosted: Wed Apr 04, 2007 4:59 pm
Dorman products can be purchased at just about any parts store; many have racks of drawers in the store where the items are kept.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Apr 04, 2007 5:27 pm
hello,
and do'nt forget that the end studs (front and rear) go thru to the water jacket,and need sealant on them.
regards,Rod :D
PostPosted: Thu Apr 05, 2007 6:54 pm
ok thanks for the responses guys. ill check the local parts stores.
thanks
russ
PostPosted: Wed Apr 23, 2008 8:39 am
I just called NAPA and they cross referenced number and will get mine over night. They did not have cross for brass nuts but any will work I guess. I had to order in packs of 10. As far as the cone nut and triangle washers, I was pleasently suprised when I received my manifold from 1A Auto, they included a complete set of triangle washers, 2 cone nuts, 2 brass washers AND the correct heat stove. (I think thats what its called) brings heat up from exhaust pipe.
I will let you know what I get.
Jim
Jim
Moon Lite Vans Inc.
PennsylVANia Van Council
PostPosted: Wed Apr 23, 2008 9:01 am
Here are pics. Also, I forgot to mention, they also included center stud and nut to attach manifold to manifold. I will have to pick up other two bolts but thats easy.
Jim
Jim
Moon Lite Vans Inc.
PostPosted: Fri Apr 25, 2008 8:12 pm
I'll have information on this project. At work now but a teaser.
Enjoy,
Jim
Jim
Moon Lite Vans Inc.
PostPosted: Sat Apr 26, 2008 6:47 am
Car Model: 1967 Dodge Dart 270
Awsome Van :D
PostPosted: Sat Apr 26, 2008 8:48 am
Awsome Van :D
No joke. He should do it up like the van from Old School :lol:
PostPosted: Sat Apr 26, 2008 11:38 am
Jim,
Nice work and pics! Let us know how it all comes out. :D
PostPosted: Mon Apr 28, 2008 8:48 am
Thanks for the compliments guys.
I think I need some final tuning. I didn't have time to do any since I got her running before work and had to get to a van run after work. It was a 2 1/2 hr drive and she ran like It never ran before. The free flowing exhaust makes a heck of a difference. I was cruising in OD at 75 and she hummed along.
Also, not sure if I mentioned but I used the POR15 Factory Manifold Gray on the new piece. It smoked for about 15 min, or it was the gasket, not too sure. But no peeling or flaking after the curing process. It looks real nice.
Now my question is, Is there anything specific I should change with carb or timing settings now that I have removed smog equipment?
I contacted the company that I pruchaced manifold from to see if there was any way they could put a kit together with the acorn nuts, brass washers, triangle washers, center bolt and nut, and heat stove. They are looking into it. Hopefully they can get it together and offer us a nice price.
What kind of interest is there for this?
"Old School"? great movie but a little more work on the slanty to make her sound like that or smoke the hydes.
Jim
Jim
Moon Lite Vans Inc.
PostPosted: Mon Apr 28, 2008 9:52 am
Jim,well done,I like it 8) Just a FYI,on both my slant vans I wrapped a piece of heater hose around starter wires where they come out from under floorboard.Not a big deal but it looked like it had been rubbing on the 83 so figured a little "padding" wouldn't hurt.Hey,if you're planning on vanning out this way someday I'll let you detail my 80 slant,you did good on your's.Nice :)
PostPosted: Mon Apr 28, 2008 10:07 am
Jim,
Great shots! Yes, the POR-15 does smoke a little at first but bakes right on and cures. It has held up on my rig for 2 years now since the rebuild. Great stuff!
I would think the kit would sell like hot cakes.
With a distributor recurve you will be smoking those hydes!!!!
Nice job!
