It is currently Thu Nov 26, 2026 3:56 am
PostPosted: Mon May 05, 2008 3:59 am
My power steering pump whines all the time. It still works, though. Can I buy parts to rebuild it at the auto parts store? Is it better to get a rebuilt one? Cost?
Never had a power steering car before. :roll:
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Mon May 05, 2008 9:35 am
I'm not 100% sure on this but I think it is better to buy a new pump.
PostPosted: Mon May 05, 2008 10:39 am
See this thread and try the air bleed procedure described therein. Also check the condition of your fluid. If it's dark, gritty, burnt-smelling or otherwise "off", you're probably in the market for a new pump. It's going to be hard to find anything but a "reman" of questionable quality; about all you can do is steer(!) clear of known-lousy brands like Cardone.
PostPosted: Fri May 09, 2008 10:22 am
My '71 Saginaw pump suddenly developed a big leak at the front main seal; my local parts had a rebuilt kit for <$20. The rebuild was straight forward; easier than a carb rebuild. A couple of points
1a) the output hose/tube assembly was rusted solid and I had to get a not-quite-exact aftermarket replacement
1b) NAPA tried to palm off the wrong size (3/4") return hose on me when I specifically requested the right size (11/32"); eventually I got some 11/32" from a dealership
2) it takes a special puller to remove the pulley - I used an inexpensive one from Harbor Freight; I also have a KD Tools' one
3) There was a choice of 2 O-rings due to a production change - the details on which to use were on the backside of the instruction sheet in small print
