It is currently Mon Oct 26, 2026 9:23 am
PostPosted: Sun Dec 01, 2002 7:27 am
guys,
i have a 170 that i am thinking about turbocharging. I also have a turbo from a mitsubishi 2.5. do i have a piston option with the 170 motor? would the 2.2 pistons work in this application?? also, wouldnt the smaller motor be more responsive to the smaller turbos that are so readily avalable?
 Post subject: Responsiveness of turbo
PostPosted: Sun Dec 01, 2002 9:52 am
In theory it should. . . similar turbo output, less displacement to fill with charged air.
Cheers!
Al T
 Post subject: Pistons
PostPosted: Sun Dec 01, 2002 12:15 pm
You're going to have very low compression if you just put in a set of 2.2 Turbo pistons into a 170. They drop the compression to unacceptably low levels on a 225 if you don't put in 198 rods, and it'd be worse (I'm guessing around 6:1) on a 170.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sun Dec 01, 2002 6:19 pm
Muhahahaha!! IMAGINE THE BOOST PRESSURE :D 30+PSI!!! WHOOOO HOOOOO!!!
Justin
 Post subject: Cr
PostPosted: Sun Dec 01, 2002 7:57 pm
Hey Matt,
What does the CR work out to be when using 2.2 pistons with the 225 rods/crank? Anywhere near 7.5:1? I tried calculating it before, but I wasn't sure about my numbers.
If it's near 7.5:1, I might be crazy enough to try it on the street.
'68 Dodge Dart 4dr Sedan
 Post subject: another option
PostPosted: Mon Dec 02, 2002 5:37 am
If you were to use 2.2 pistons on stock 225 or 170 rods, you could gain back your compression by milling off about 0.110 from the block and 0.110 from the head (I don't remember exact comp height difference, but this is very close). These are both doable numbers and not difficult to have done. You can also, then, chose your compression ratio at will.
PostPosted: Mon Dec 02, 2002 4:33 pm
Now I thought you WANTED lower compression pistons if you ran a turbo.
Am I wrong here? What's the optimal CR for turbo-ing a 225?
PostPosted: Mon Dec 02, 2002 6:30 pm
Lower compression with a turbo will minimize your chance of detonation but will kill your low end acceleration. I would go with stock compression and control detonation with octane and ignition timing.
Bob D
PostPosted: Mon Dec 02, 2002 8:49 pm
Bob D
Cool. Now I don't have to buy new pistons :p
Users browsing this forum: Ahrefs [Bot] and 8 guests
