It is currently Tue Oct 13, 2026 4:20 am
PostPosted: Wed May 14, 2008 10:36 am
ok here is my question. are performer edelbrock carbs physically the same (dimensionally and linkage wise) as carter afb(avs) carbs of old? didnt edelbrock buy carter?.........inquiring minds(mind) :? wanna know..........
PostPosted: Wed May 14, 2008 1:14 pm
Edelbrock didn't buy Carter, but they did buy the AFB and AVS carb designs, prints, and tooling from ACF Industries. The bolt-up patterns haven't been changed.
PostPosted: Wed May 14, 2008 4:04 pm
I thought Weber was making the carbs and Edelbrock was butting there logo on them.
PostPosted: Wed May 14, 2008 4:21 pm
You could be right about that; I'm not exactly sure of the manufacturing/marketing arrangement.
PostPosted: Wed May 14, 2008 4:41 pm
The Edelbrocks are good carbs and use the same jets and rods and springs as the carters. The only edelbrock carb that has problems that I know of is the 750. Whoever designed the boosters for that carb either was working for Holley on the sly or was on drugs. Dave
PostPosted: Thu May 15, 2008 1:59 am
thnx for the replies. how about the throttle linkage? is the new edlebrock 500cfm's linkage the same as carter's? the reason, - i wanna keep my original pedal and bell crank 61 lancer linkage, and kickdown :wink: .........ss
PostPosted: Thu May 15, 2008 4:17 am
The air horn is a different diameter. The OEM Carter AFB used a smaller dia air cleaner opening. Not sure on the other stuff.
PostPosted: Thu May 15, 2008 10:58 am
The air horn opening, is now the same size as a holley or a thermoquad. Dave
PostPosted: Thu May 15, 2008 11:36 am
well, i just bought a new eddy 500cfm off the bag for $238 shipped!! summit wanted $288 shipped !!!!!! :shock:
PostPosted: Thu May 15, 2008 12:38 pm
I bought an Edelbrock 1406 (600 CFM, not a good slant size) that was missing it's electric choke at a garage sale for $20. 8)
PostPosted: Thu May 15, 2008 3:53 pm
well, this will be my first new carb ever(ive owned 14-pre 1975 cars and hotrods). it will be nice to know i have a "good" carb for once........... :)
 Post subject: test pic
PostPosted: Sat May 17, 2008 1:58 pm
test pic
PostPosted: Sat May 17, 2008 9:35 pm
Edelbrock, Weber, Carter....Same poop, different dog. :shock:
I have 2 1405's and a 1406.
I tried a 1405 on my Slant and it had some good points and some bad points. Yes, I have a strip kit and played around with jets and needles.
I ended up with the 1406 because someone else couldn't get it to work on a Slant.
They look cool laying on the shelf next to each other though. :lol: :lol:
 Post subject: lancer
PostPosted: Sun May 18, 2008 8:16 am
Not sure of the carb ?,but that is one sweet Lancer :D
the path i walk, i walk it with my own resolve
PostPosted: Mon May 19, 2008 5:44 am
So if you have a 500 cfm Edelbrock carb on your slant six, just driving around with the primaries it should be flowing @ 250 cfm, is that right?
'78 Volare 225
'67 Charger 318
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 10 guests
