It is currently Sun Jun 14, 2026 4:12 pm
 Post subject: 4 barrel linkage
PostPosted: Mon Jun 09, 2008 9:28 pm
Im setting up a 4 bbl carb and was a little confused about linkages does anyone have pictures of there four barrel setup?
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Mon Jun 09, 2008 9:55 pm
Here's my old car with the carb off. Just picture a Holley with the primaries toward the driver's side. The linkage pulls the primaries open. The bellcrank is just a piece of 1/8" thick 1" steel strap with a 3/8" hole drilled in the middle. It pivots on a bent 3/8" bolt in the cylinder head lifting hole. There is a washer on either side of the bellcrank and a nylock nut holding it up. A lock nut on the bottom of the bolt keeps the works in place.
 Post subject: Mounting 4bbl linkage
PostPosted: Tue Jun 10, 2008 12:45 am
Josh225-
I think you just solved 1/2 of my carb mount prob;your sublimely simple stud & bellcrank WAY easier than my Rube Goldberg-esque concotion(s) necessated by my insistance on having the primaries parallel to the head and on the outside(driverside) of the int.manifold.
Now I've got the kick-down/line-pressure (trans) linkage to figure out,am trying to visualize how to incorperate a GM/Lokar TV cable onto the stud & bellcrank assy.Not having a kickdown rod (there) will be helpful when time comes to install header(s) :D Warren
"Faith in Science"
 Post subject: ...and the trans ...
PostPosted: Tue Jun 10, 2008 1:01 am
After going back & reviewing your posted photo the solution was aparrent, just tie the TV cable end to the throttle cable end. Any geometry/range of travel issues pertaining to the trans's line pressure lever can be solved by lengthening or shortening the lever. Theoretically. :roll:
"Faith in Science"
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 15 guests
