It is currently Sat May 30, 2026 12:59 pm
Post new topic  Reply to topic  [ 29 posts ]  Go to page Previous 1 2
PostPosted: Fri May 23, 2008 7:38 am
well as some of you know I have a 2dr '79 Volare with a blown slant, i just picked up a '76 slant and tranny (for a $100, out of a dart, ka ching !!), now I"m in the process of tearing it apart( because it had sat for 3yrs) going to have the block hot tanked and magna fluxed, and give it a basic rebuild.
But I am not sure if it has a cast crank, or forged, how can I tell ?
Is there a way to make the crank lighter ? ie knife edging, and radiusing, and is it worth it ?
being a '76 is it a 225 or 198 ? I already have the head off and couldn't find the stamp anywhere,
Thanks for all the help guys, and eventually I will have her running again,
-Mike[/b]
PostPosted: Fri May 23, 2008 10:30 am
...But I am not sure if it has a cast crank, or forged, how can I tell ?
Post a photo of the crank or find it's part number, that is usually in the middle of the piece.
Apart form basic deburring, crankshaft weight reduction is not worth the trouble.
Being a '76 is it a 225 or 198 ? I already have the head off and couldn't find the stamp anywhere...
The number should be on the top deck surface, near the coil mounting area.
PostPosted: Tue May 27, 2008 5:45 pm
Well I finally got the oil pan off and there is nothing but black crusty sludge on the crank and in the pan, looked on the crank and couldn't find a part number but i will finish cleaning it tomorrow. there is no part number by the coil pad, i think the block has been decked, because i measured the piston to deck height of the blown block and my new '76 block, and the '76 is about 1/16th of an inch shorter.
I found a number on the side of the #6 cylinder ( on the block, passenger side) 5B368645
1
Also the distributors, and brackets are different between the '76 and '79, are there any other differences between the '76-'79 engines ?
Thanks,
-Mike
PostPosted: Fri May 30, 2008 10:01 am
Also the lifters are a pain in the ass to pull out from the top, flipped block over and can barely push them out, is that normal ?
Do the load from the bottom ?
Also is it better to stick with mechanical lifters/rockers/pushrods/cam, or is it better to convert it to hydraulic ?
Is there a hydraulic roller setup out there for the slant ?
Thanks,
-Mike
PostPosted: Thu Jun 05, 2008 11:35 am
well answered my own question about lifters ( had baked on oil around the bottoms, flipped block right side up and they pushed right out)
Is there a hydraulic roller setup out there for the slant ? Is it worth it ?
Also how tuneable is the carter 2bbl ? are there after market metering rods and jets available for it ? Will the eddy carb parts work ?
Oh and the block has been decked slightly
-Mike
PostPosted: Fri Jun 13, 2008 1:01 pm
I found out the Comp cams makes 2 cams for the slant still,
a
Part No.K642404 Competition Cams High EnergyTM; Camshaft Kit
High Energy(Tm); Camshaft Kit: Mechanical Flat Tappet; 800-4500 Rpm; Advertised Duration 252 Int./Exh.; Valve Lift .435 Int./Exh.; Lobe 110 Deg; Includes Cam; Lifter; V.Sprng/Ret./Lock/Seal; Timing Set;
and a
Part No.K642414 Competition Cams High EnergyTM; Camshaft Kit
High Energy(Tm); Camshaft Kit: Mechanical Flat Tappet; 1200-5000 Rpm; Advertised Duration 264 Int./Exh.; Valve Lift .440 Int./Exh.; Lobe 110 Deg; Includes Cam; Lifter; V.Sprng/Ret./Lock/Seal; Timing Set
both complete cam kits are $379.99 through advanceautopart.com, but which one would be better for a daily driver/occasional strip car ?
Also Should I stick with the carter 2bbl ? or switch to a holley ?
I have a holley 2bbl # R 6889 came off a 400BB, buddy gave it to me for free, I know it will need some kind of adapter plate its base is about 3/4 of an inch wider than the carter 2bbl, but is it over kill ? it weighs twice as much as the carter, but will it offer better performance ?
-Mike
PostPosted: Fri Jun 13, 2008 2:32 pm
a
and a
Read this thread http://www.slantsix.org/forum/viewtopic.php?t=21400 then give Tom a call. Tell him what you have and what kind of use you will give the car. Let him make a reccommendation. Should be a much better deal.
PostPosted: Fri Jun 13, 2008 7:54 pm
Comp will grind about anything you want. I got an Extreme Energy cam from them a few years ago. It worked very well. :D
PostPosted: Tue Jun 17, 2008 9:18 am
Thanks charrlie, I will definitly be giving tom a call, about cam selection. i finally broke down and am selling my tool box which should give me about $2,000 to play with, i am shooting for 300WHP NA ( but if its easier I will run nitrous), and still keep it a daily driver, about how much power loss will be encountered through out the drive train ? just so I know what kind of engine (crank) Hp to shoot for.
What would you guys recommend for a stout combo to hit those numbers ?
I am sending the block out next monday to be prepped, and decked, I kinda wanted to stick with a stock bore just freshen up the cylinders with a light hone, or should I over bore it ?
They will finish cleaning it and sonic checking it and also magna fluxing it for me.
What would be a good forged piston to use if I stay with a stock bore ?
If they check (size wise) out ok should i keep the stock rods and crank(polish the crank) ?
port and polish the head and combustion chambers
Would it be easier to use nitrous to hit my 300whp goal ?
I am not sure what gears in the rear I was told ( its a '87 5th ave 8 1/4 rear) 2.44 ?s open of course, what would you guys reccomend for a rear gear ? suregrip ? true trac ? high or low gear ?
PostPosted: Sun Jun 29, 2008 1:28 pm
would swapping in 198 rods be worth it or should i stick with my 225 rods ?
Can i stick with stock pistons or should i go with either silvolite 1250 flat tops or 1294 2.500' Dia. Head Recess .210' Deep. Low Compression pistons ?
How do I determine compression ratio, or can the machine shop do that for me ?
-Mike
PostPosted: Sun Jun 29, 2008 1:45 pm
also when porting the head (gasket matching) there is a thick rib leading up to the valve guide, can that be ground out and blended for better airflow ?
will it hurt the valves rigidity if the valve guide is also ground down to blend the bowl better ?
-Mike
PostPosted: Mon Jun 30, 2008 5:26 am
Mike
My sugestion is to READ and Search on this site til you cant see straight. Write what works and what you want down on paper. Then look at your actual budget. Then stick to it.
Just my 02.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Jul 31, 2008 12:25 pm
-Mike
Id keep with the 225 rods. 198 rods are not the easiest thing to find and to me just not the worth the average $150 asking price. The 198 rod seems like it would be more prone to bending under something like heavy nitrous use or something. Id say stay with 225 rods and use the arp rod bolts. My 2 cents on this...
PostPosted: Sat Aug 02, 2008 11:52 am
Mike,
When your setting up a head for race only and using the bigger valves, some folks do cut that down to smooth it out but, yes it doesn't support the valve as well, but you can get bigger diameter valves with bigger stems.
On my head it was smoothed and blended all the way around the valve guide to enhance the flow and still provide maximum support.
On porting we spent more time opening up the exhaust side compared to the intake. It does help make a little more power.
