It is currently Fri Nov 27, 2026 11:44 pm
 Post subject: Overdrive transmission
PostPosted: Fri Jun 13, 2008 4:03 pm
Over on another board (c-body) there has been a lot of discussion about overdrive transmissions and the common feeling is that there really isn't much out there to bolt up behind a 440 or 383 (at least cleanly). But I posted some questions about a diesel conversion, or doing something to improve the eficency of the 273. I just thought what about an overdrive? Or even a five speed? Anybody know of anything that could bolt up to a slant six?? :D
PostPosted: Fri Jun 13, 2008 4:38 pm
There are numerous ways to install a 5-speed or a 4-speed overdrive transmission behind a slant-6. This has been discussed many times in the past. Please spend some time using the board's search function to read up on the old threads.
PostPosted: Fri Jun 13, 2008 8:06 pm
http://tinyurl.com/36fvsx
GearVendors
http://www.gearvendors.com/hrdodge3s.html
 Post subject: Yep...
PostPosted: Fri Jun 13, 2008 9:53 pm
The 'quick and dirty' way to an OD manual tranny is the Mopar A-833OD box... for the 273 getting a bellhousing from a 1975+ 318 vehicle would be the best shoe-in for making the tranny work... for the slant, they were fairly common in A/F bodies after 1975, and for the longer version check on 1975+ D-100 trucks (that tranny works for B/E bodies and trucks...)
Automatic overdrives become a different story....
