It is currently Thu Jul 16, 2026 4:06 am
 Post subject: A-Body floors
PostPosted: Wed Dec 18, 2002 12:49 pm
I'm new to this forum and these cars in general. I have a 1962 Valiant. It is in bad need of front floor pans. All of the main suspension points seem to be good. Shock towers are good. I know no one makes body parts for these cars. Does anyone know of a car that floor pans could be removed from and welded into this car or do I have to fabricate my own? Has anyone made their own? Did you weld them or use the new glue peope in this area are talking about?
PostPosted: Wed Dec 18, 2002 10:04 pm
Site Admin
One option is to clean up the rust and then use fiberglass.
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Thu Dec 19, 2002 7:33 am
I jus cleaned up my badly rusted trunk. (I thought I needed to replace the floor of the spare compartment)
I cleaned the rust out and then coated it with POR-15. It worked very well. I patched a few of the holes with and epoxy. I'll see how it holds up.
POR-15 also has some fiberglass mesh that you can use with their product. I bought some but I didn't end up using it. I have been told that it works really well for patching holes.
It all depends on how bad your pans are.
John Killn
PostPosted: Fri Dec 20, 2002 12:38 pm
Thanks for the info. The pans are gone. Can't really tell what they look like. Have a friend that owns a yard. I am going to try to go there this weekend to see if it looks like anything will fit. I want to use metal. I believe it to be stronger. Hope to have a strong running /6 when I get done with car. Lots of body work first.
PostPosted: Fri Dec 20, 2002 5:38 pm
I had a 68 Valiant that over time the floor pans rusted out and disappeared. I cut out any rusted metal and got some galvanized sheet tin of the same gage as the original floor. I cut it to fit and put what ever curves in it that it needed. I just ran a bead of tar type sealer around the edges and screwed the tin to the remaining floor and sealed it with some undercoating from underneath and on top. I removed the seats and the carpet and undercoated the whole floor then put everything back in. After you undercoat the floor let the car sit for a couple of days with the windows open so it will dry. Then put everything back together. After you do this there will be no more rust problems.
