It is currently Fri Jun 19, 2026 10:55 am
PostPosted: Tue Jun 24, 2008 10:45 pm
Got a chance to do some carpet for a set of 16X8 Mustang wheels with tires :D
I think they are "Pony wheels????" Kind of like Motor Wheel Spiders.
Lots of fun VS my alloy Jeep 15X7's?
What size can I run?
PostPosted: Wed Jun 25, 2008 5:54 am
I have 16X8 mustang rims on my 64 Dart with 245/45-16s. You will need some wheel spacers to get them to sit at the right offset.
PostPosted: Wed Jun 25, 2008 7:06 am
When I do the factory disc conversion I will still need the spacers?
My rear is going to be a '66 B body 8 3/4.
PostPosted: Wed Jun 25, 2008 9:24 am
You will be close in the rear, maybe no spacers.
Front discs will still need some spacers - at least 0.5". You will run into the UCA and/or U balljoint, and maybe tie rod end with rim.
PostPosted: Wed Jun 25, 2008 8:02 pm
I just installed 17x8 bullit wheels on the rear of my car, no spacers perfect fit P245/45ZR17 tires no rubbing with stock spring location & 67 b-body 8 3/4".
http://www.forabodiesonly.com/mopar/sho ... hp?t=38777
I will hopefully get the front done this weekend if all goes well.
mopar or no car
68 Valiant 100 2dr post /6 a-904 susp mods
78 Ramcharger 4x4 360 727 3/4t 33"
67 Charger 383 4bbl 727 trick suspension
PostPosted: Thu Jun 26, 2008 6:16 am
I checked your link there. What did those wheels set you back and where did you buy them? Do you know what the back spacing is, or the offset?
How did this effect the ride, and or the economy of the car?
Thanks. Sam
PostPosted: Thu Jun 26, 2008 6:55 pm
I got them used on craigslist locally $300.00 for the set, they do have some curb rash. They are 1998-2004 mustang bullit 17x8" 5.72"BS with I think 30mm offset. With the P245/45ZR17 falken I got were almost the same overall diameter as my P235/60R15 on 15X7" rims. I love the handling with them.I also have all poly bushings on the rear & new road race/perf street leafs from Firm Feel & addco 3/4" rear sway bar.
mopar or no car
PostPosted: Tue Jul 01, 2008 3:56 pm
The factory "bullit" wheels will fit on the rears, but the hub centers are too small to fit on the front of a-bodies. I have a set of those mustang wheels that I tried to put on my car, and the hub centers were too small up front.
PostPosted: Tue Jul 01, 2008 8:58 pm
They are close. I just opened my stock 16X7.5 Mustang wheels with a drum sanding wheel on my elec drill in about 5 min - fit fine now.
PostPosted: Tue Jul 01, 2008 11:12 pm
The ones I am getting have the wavy flower petal plastic silver pony center.
I don't know what year etc.
PostPosted: Wed Jul 02, 2008 7:34 pm
It seems to me the back space numbers do not add up. If the back space is 5.72 on the Mustang wheels, and the stock back space should be 4.5" with 8", then you need 1.25" of spacers there. If it is different than that, then your scrub radius in the front will be wrong. Comments?
Sam
PostPosted: Wed Jul 02, 2008 9:09 pm
Scrub radius is different depending on your spindles and LCAs anyway on a Dart (KH vs. drums vs. late discs). I don't think 1/2" is going to kill you. 4.75" is the correct backspace for an 8" rim on a Mopar. I have 0.7" spacers on the front of my Dart.
I am just amassing parts to put the 11.75" Mopar rotors and Wilwood calipers on my '68. Should be a great swap and I'll have BBP all around. Those brakes are killer.
PostPosted: Thu Jul 03, 2008 12:03 am
I machined the rotor snout on my 11 3/4" rotors so the wheels fit perfect to the rotor.
mopar or no car
PostPosted: Thu Jul 03, 2008 4:26 am
I hope that is just a metaphor. :wink: I understand your math on the backspace now. I am 1/2" off the other way. And I don;t like the way it changed the car. The wheels do not want want to self center as readily out of a highway exit as when it had the stock cop car wheels. You end up doing more "steering".
That feeling was why I chose to buy the Toyota Matrix over the Yaris. The Yaris has electric power assist which really creates a disconnect from the road. I guess that kind of steering might become more comon. In other regards I liked the Yaris. But that steering was a deal breaker for me. That is why I want to optimize the steering geometry on the Dart if I can.
Sam
PostPosted: Thu Jul 03, 2008 4:33 am
I hate power steering of any kind, except on large vehicles...
One possibility with your steering problem is too much difference between track front and rear on the car. I have seen this with different wheels/brakes/spacers on front and back, and it is very annoying. Try throwing 1/2" spacers in on front, then back and see if problem gets better.
I am getting ready to try a 16:1 box in the '64. Should be light enough so it's not too much effort. The 24:1 has always been great except in really tight corners.
