It is currently Wed May 20, 2026 3:53 pm
PostPosted: Thu Jul 31, 2008 6:09 pm
ya im looking into buying a hurst quarter stick shifter for my 68 dart with a stock 904 trans. Im just not sure wether i need to buy the forward or reverse valvebody shifter.
PostPosted: Thu Jul 31, 2008 6:23 pm
With a stock valve body you want the forward pattern shifter. Only with a reverse pattern full manual valve body do you want the reverse pattern shifter.
PostPosted: Thu Jul 31, 2008 6:30 pm
is it hard to swap in a valvebody, and what has to be done?
PostPosted: Fri Aug 01, 2008 9:47 am
Depending on what valve body you get, some are a simple bolt in while other require holes drilled in drums, servos blocked, etc..
PostPosted: Fri Aug 01, 2008 9:01 pm
A funny related story...
My brother just installed a reverse valve body with a trans brake this season in his muskrat drag car. His shifter had the trans brake button in the T of the handle. The first time he launched, he let go of the button and bam! He shifted into second gear :lol: :lol:
Later that day we wired in a second switch 8)
Chris'
Autobody
Restoration
Service
PostPosted: Fri Aug 01, 2008 9:23 pm
Mine's on the steering wheel just for that exact reason. :lol:
