It is currently Fri Jun 19, 2026 4:51 am
PostPosted: Sat Aug 02, 2008 8:11 pm
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
Getting ready to go through the 225 in the '73 duster and wanted to know if anyone here fomerly had electronic ignition and changed over to hei style? I have the stock mopar orange box ecu on my '73 and wonder if it would even be worth the time to convert the car over to an hei or just keep what I have?? I know that by doing this I could eliminate the use of a ballast resistor. Any thoughts??
PostPosted: Sun Aug 03, 2008 6:41 am
I can testify that the HEI is worth it. I saw Charrlie S 's HEI conversion and the spark is 10X better than my stock Mopars. I am gathering the parts to do this on 4 cars right now. :D :D :D
Not sure why Ive waited so long. :oops:
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Aug 03, 2008 8:58 am
This post goes into detail on how & why the HEI is better.
PostPosted: Sun Aug 03, 2008 7:14 pm
Check out Dan's link - - - Game over.
PostPosted: Sun Aug 03, 2008 9:25 pm
Im kinda confused about the use of a relay though as I dont recall seeing it before on the how to page??
PostPosted: Sun Aug 03, 2008 9:46 pm
It's right there in the how-to article, and the reason for it is explained. Where's the confusion...?
PostPosted: Sun Aug 03, 2008 10:13 pm
Because the original posting IIRC did not feature anything about a relay??
PostPosted: Mon Aug 04, 2008 9:34 am
That is correct, it was added long after the original HOWTO post. After a member posted some solid poor results when not using a relay, it was added to the HOWTO post as part of the instructions.
If your wiring is good/new you can check the voltage at the HEI module. If the drop is minnimal a relay is not necessary.
PostPosted: Mon Aug 04, 2008 12:10 pm
Does anyone have a part# for the relay listed on the how to page?? What is it under on rockauto.com????
PostPosted: Mon Aug 04, 2008 5:15 pm
Here's the best price I've found on a genuine Bosch/Tyco relay. It is the 5 pin module, but you just leave the middle tab unconnected. If you want a socket harness, they have a good price on those too.
http://www.mcmelectronics.com/product/26-534B
-Moose
1966 Clark Cortez, Industrial /6
Users browsing this forum: Amazon [Bot], Darcy225, Google [Bot] and 2 guests
