It is currently Thu Jun 18, 2026 5:48 am
 Post subject: Industrial Slant Six
PostPosted: Tue Aug 12, 2008 2:09 pm
I have an industrial slant six that I'm putting into my '67 A-100 van. The block is marked IND 225 and has some massive counterweights on the crank.
One odd thing is that my damper requires a bolt to hold onto the nose of the crank. Anyone run into this before?
Nate the skate
1994 Dodge B250 Van, Conversion by Elk
1972 Dodge B200 Sportsman Maxiwagon
1967 Dodge A100 C&P Telephone Van
PostPosted: Tue Aug 12, 2008 4:46 pm
If your damper won't stay on the crank without a bolt, then the damper or (less likely) crankshaft is damaged.
PostPosted: Tue Aug 12, 2008 6:18 pm
Just to add. Nothing looks out of the ordinary. The crank has the keyway as normal, but the strange thing is that the crank nose is splined as is the inside of the balancer. Odd.
Nate the skate
