It is currently Thu May 28, 2026 1:15 am
PostPosted: Tue Aug 12, 2008 9:21 pm
its basically jibberish to me, found an old marine camshaft, looked up the numbers and this is what it told me
Durations at .050 lift
int 198*
ex 203*
Cam Lift
int .270
ex .276
Lobe centers
in 106*
ex 112*
I don't quite understand these figures, usually people speak in degrees like, "Mine is a 270*" or what ever, are these different numbers at different specs? ha ha, I am confused, would appreciate all help!
thanx
morgan
PostPosted: Tue Aug 12, 2008 11:01 pm
Looks like the '71 and up cam which was used earlier as the marine cam. It's about 244° advertised duration and is ground 3° advanced with 109° lobe separation. Multiply the cam lift by 1.5 to get the gross valve lift. Take away the lash setting from that to get the net valve lift.
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
