It is currently Fri Aug 28, 2026 1:48 pm
 Post subject: Throttle Body help
PostPosted: Tue Aug 12, 2008 1:10 pm
Would this throttle body be a good choice for a turbo blow-through setup for MPI? I would mount it upon a super six manifold with a homemade adaptor
http://store.summitracing.com/partdetai ... toview=sku
PostPosted: Tue Aug 12, 2008 5:29 pm
You could use that but why not save some money & goto the wreckers & get a throttle body off a 4.6 ford or chevy or something for about $20.00 instead of $300.00 for the eddy one.Then you have more money for other components(just my .02)
mopar or no car
68 Valiant 100 2dr post /6 a-904 susp mods
78 Ramcharger 4x4 360 727 3/4t 33"
67 Charger 383 4bbl 727 trick suspension
PostPosted: Tue Aug 12, 2008 6:25 pm
90 mm is downright huge for a slant. I used a junkyard 4.6 Ford throttle body myself; it's more like 65 mm.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Tue Aug 12, 2008 10:38 pm
If you don't want to go to the junkyard get one of the bored over Jeep 4.0L ones on ebay. Those are usually quite nice and should be about the right size. However, these guys are right, don't bother with high dollar stuff unless you absolutley have to. Besides there's plenty of Mustangs to steal TB's off.
PostPosted: Wed Aug 13, 2008 9:54 am
I use a jeep 4.0 tb on my efi -- The GN and GNX Buicks dont have a huge TB.. The Air is forced so it's going to get in there no matter what.
The haed and valves will hold it back more than the TB will.
